Details on E-Fuel
Old Dec 13, 2011 | 03:04 PM
redman84's Avatar
redman84
Details on E-Fuel
So I'm getting ready for e-fuel. Not so much because I need it but because I want it. I like the idea of a clean valley and easier leak detection mostly. I just want to get it flowing and will continue to upgrade it as I have time and funds. I'm going to use a single SD pump for now and a chopped up stock FPR until I can get an Aeromotive sometime. Then I'll get to maybe a better pump and uprgrading lines. I have some questions before I buy the rest though.
Why do folks use nicer pre-pump units like fuel manager and a napa spin on for post pump? As long as you have the correct filtration at each spot could you just use a spin on at each?
Is an in-filter heater or hand primer pump necassary? I do like the FM screw on see through bowl and think I'd still like to have a water in fuel light too.
I've seen people use anywhere from 20-150 micron pre pump and 2-5 post. What's really needed there? Can a 30 flow as much as a 150?
Old Dec 13, 2011 | 03:08 PM
fordpride's Avatar
fordpride
I'd like to know the answers to them to cause I'll be doing mine in a couple weeks
Old Dec 13, 2011 | 03:22 PM
strokin'_tatsch's Avatar
strokin'_tatsch
The filtration is up to you really. A lot of us use 2 micron filters just to get the cleanest fuel possible feeding the injectors. The stock filter is around 20-25 micron, so a 2 or 5 micron will be significantly better than stock.
Old Dec 13, 2011 | 07:45 PM
redman84's Avatar
redman84
Thanks man.
So why don't more folks use the cheaper spin on bases and filters pre and post pump? Does it have anything to do with a need for the in-filter heater or hand primer pump? Do you need a heater here in Texas Travis?
Old Dec 13, 2011 | 09:56 PM
bad12jr's Avatar
bad12jr
Here are most of the parts I used. I'll get a filter pic up shortly.
Old Dec 14, 2011 | 07:43 AM
tshrager's Avatar
tshrager
Subscribed. Thanks for the parts list Jeff
Old Dec 14, 2011 | 12:14 PM
strokin'_tatsch
Originally Posted by redman84
Thanks man.
Nah, you don't need a heater. I haven't had a fuel heater for the last 4 years and haven't had any issues. Also don't need the water in fuel light as long as you keep up with regular maintenance on your filters and drain them. I change my filter every 6000 miles(every other oil change) and never have problems.
I only have to buy one filter as my 100 micron is an Aeromotive inline stainless filter that only has to be taken out, clean, and re-install. So I only have to buy the 2 micron Dahl filters for the water seperator. I like the Dahl, but you could use the cheaper spin on bases and filters both pre and post pump and use some good Baldwin filters or something. A lot of people do that actually. Just make sure of the micron ratings your getting.
Old Dec 14, 2011 | 12:51 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Originally Posted by strokin'_tatsch
...The stock filter is around 20-25 micron, so a 2 or 5 micron will be significantly better than stock.
You sure about that?
I'm pretty sure the stock filter is around 5 - 7 microns.
There are 2 types of filters/water seperators. One type of water sep. uses a spin on cartrige and has the type of media in it to trap water. The other does not, so they use a different housing/bowl etc to get the water out. That's how I understand it, though I might be technically off.
Nothing wrong with either, IMO, just pick one and go with it. Personally I use the spin-ons, they are cheaper and do a good job. The water sep filters have a drain so they are prettymuch just like the stock filter, IMO.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Dec 14, 2011 | 01:55 PM
strokin'_tatsch
Hmmm... Guess I read wrong. Not the first time and surely won't be the last!! LOL Thanks for the correct info Jim. Maybe I was thinking about the oil filter??? I think that may be what I was thinking. LOL My bad!!!
GarageSpec
Dec 9, 2011 10:07 AM
JonathanN
107
May 24, 2010 11:15 AM
andrewk
Feb 5, 2009 01:42 AM
yellow401
Oct 27, 2007 08:08 AM
glasseater
Jul 6, 2007 05:43 PM
