need advice
Old Dec 13, 2011 | 11:29 AM
theo96's Avatar
theo96
need advice
i have a 99 expedition xlt 4wd
my problem is my cel is on and my o/d light flashes now i just had my tranny replaced a few months ago and i have had the sensor on it replaced 3 times because im forever being told it was the sensor
the engine surges at average speeds the o/d lights flashes intermittently amd its funny when it starts flashing if i slow down or stop for a minute it stops flashing please help me i have spend thousands on a tranny and fixing it and still the same problem
Old Dec 13, 2011 | 07:43 PM
alloro's Avatar
alloro
You have a misfire. Have the vehicle scanned to see what the trouble code is. This will help by telling you which cylinder is the problem.
Old Dec 23, 2011 | 12:58 PM
theo96's Avatar
theo96
i get codes p1747 and p0401
Old Dec 24, 2011 | 12:53 AM
alloro's Avatar
alloro
The P1747 code is telling you that the pressure control solenoid inside the tranny is showing a short. This could indicate a problem with the solenoid inside the tranny or a short in the wiring running to the tranny. Further diagnostics are necessary to determine which.
The P0401 code indicates insufficient EGR flow. This could be a bad EGR valve or the ports running to (or from) the EGR valve are blocked with carbon build-up. Remove the EGR valve to inspect the ports.
Old Dec 24, 2011 | 03:46 AM
theo96's Avatar
theo96
OK will check all this weekend
ESCAPESTER
Escape & Escape Hybrid
Oct 13, 2008 09:31 PM
bhildreth
Nov 25, 2006 09:15 AM
pastorbill30
Modular V10 (6.8l)
Aug 2, 2005 01:37 PM
allenw
Modular V8 (4.6L, 5.4L)
Aug 7, 2004 10:44 PM
nike33
Jun 30, 2004 08:04 PM
