Modular V10 (6.8l)
Help! EGR Problem, restrictive flow
Old Aug 2, 2005 | 01:57 AM
pastorbill30's Avatar
pastorbill30
I have a 99 V10, service engine light is on, code for restricted EGR Valve (forgot the exact number). Just replaced EGR Valve, reset code, within 10 miles it was back on again. Reset the code again, off for about 10 miles then back on again. Any advice would be helpful. What else should I be looking at? Did I waste my money on a new EGR Valve? Anybody else with a similar problem??
Old Aug 2, 2005 | 07:02 AM
rlh68050's Avatar
rlh68050
DPFE sensor
Old Aug 2, 2005 | 11:24 AM
Stan Birch's Avatar
Stan Birch
DPFE sensor
Old Aug 2, 2005 | 01:37 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yup, change the sensor first, if that doesn't fix it, make sure the EGR tubing isn't crimped and it's clear of blockage, and then make sure the throttle body port for the EGR is not clogged with carbon (VERY common!).
art k.
