Diagnostic code 402 - EGR flow excessive
Old Aug 7, 2004 | 10:32 AM
allenw's Avatar
allenw
My father-in-law has a '01 Expedition 4.6L and mother-in-law has an '00 Explorer EB 5.0L. Both vehicles are throwing the 402 code. Is replacing the EGR valve the answer or should I be looking elsewhere?
Old Aug 7, 2004 | 06:26 PM
Gary B's Avatar
Gary B
code does indicate excessive egr flow,you could remove the valve and spray wd-40 or such through the valve pindle,if the valve is stuck open the fluid will go on through.could be a bad vacuum regulator sol.or a bad dpfe sensoregr valve probally most likley.hope this helps
Old Aug 7, 2004 | 10:44 PM
Stan Birch's Avatar
Stan Birch
A defective EGR with a P0402 excessive air flow at idle, would be demonstrated by rough idling. EGR defects are extremely rare.
If there are no driveability problems, then the problem is probably caused by a defective differential pressure sensor. They are rather notorious for failure, and will toss out the same DTC.
pl77
Jan 3, 2018 02:50 PM
TrikeDawg
Feb 10, 2017 08:49 PM
96halfton
Nov 6, 2016 04:31 PM
SVTDriver97
'80-'86 HOWTO's
Jun 23, 2016 08:18 PM
1949 School Bus
Jan 16, 2016 03:00 PM
