Coolant leaking down back of engine
Old Dec 12, 2011 | 07:28 AM
mike1589's Avatar
mike1589
hey guys, now that its getting cold out, ive noticed on cold nights my 6.0 drips coolant all over the driveway (its noticeably getting worse quickly), it started off coming down the right side of the motor where the motor meets the bell housing, and now it actually seems like it does it on both sides, but much worse on the driver side. Doesnt leak at all when the trucks running, just when everythings below freezing. could this be an egr problem? its hard to trace where it starts as its hard to see the back of the motor up top..
Old Dec 12, 2011 | 08:38 AM
dukie1877's Avatar
dukie1877
it sounds like its an egr cooler hose leak. Look where your egr connects do you have an orange or blue hose? Should be between the oil filter and the turbo but off to the passenger side a bit. Hows the coolant to water ratio?
Old Dec 12, 2011 | 11:40 AM
mike1589's Avatar
mike1589
I have an orange, that's the original right? I did notice it looks wet in the valley there
Old Dec 12, 2011 | 11:44 AM
Snuggyworm's Avatar
Snuggyworm
i believe if u get the replacement hose, it should be blue. supposed to be stronger material or thicker than original. it'll fit anyways.
Old Dec 12, 2011 | 11:49 AM
dukie1877's Avatar
dukie1877
Yea what worm said
Old Dec 12, 2011 | 12:02 PM
1_BIGMOFO's Avatar
1_BIGMOFO
delete the EGR..
Old Dec 12, 2011 | 03:46 PM
w_huisman's Avatar
w_huisman
His little EGR Cooler-to-Oil Cooler hose leaks a little, and you tell him to delete the EGR system?
Yup. That would fix it. Seems like a little overkill, but it would definitely do the trick.
Old Dec 12, 2011 | 04:16 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
If you determine the hose is the issue, which I would guess yes, here is a recent thread on the subject. (No you don't have to pull the turbo)
https://www.ford-trucks.com/forums/1...lp-please.html
Old Dec 13, 2011 | 07:05 AM
mike1589's Avatar
mike1589
With what you guys have said it seems to me that it is the hose, i read that write up, looks like that's what I'm gonna have to try. Thanks for all the help guys
johnsonjf
Dec 19, 2018 06:51 PM
cookingguy
Aug 12, 2015 01:02 PM
04scurs
Dec 10, 2009 11:04 PM
Scottk250sd
Mar 16, 2009 07:52 PM
neverman
Jan 18, 2007 02:26 AM
