occasional coolant leak
Old Mar 16, 2009 | 03:30 PM
Scottk250sd's Avatar
Scottk250sd
I've got an 04 6.0 PSD - this past sunday I started the truck and noticed a pretty decent size puddle of coolant on the ground - it was on the passenger side and appeared to be coming from somewhere near the firewall.. I really couldn't see the exact leak point, but I could see the trail on the transmission.. Is there something near the firewall that could be leaking like a hose or something.. When it leaked - it did it right at start-up and then not a drop after that. If sat in the driveway overnight and not a drop on the ground... Sorry for rambling...
Old Mar 16, 2009 | 03:52 PM
Stroked Out!'s Avatar
Stroked Out!
Im no expert but it kind of sounds like its the egr cooler. Is it puking for the coolant bottle?
Old Mar 16, 2009 | 03:55 PM
Scottk250sd
The coolant bottle looked dry.. Later that day I was pulling my 5er and when I'd get to a hill I could smell coolant - but when I got home the bottle still looked dry and wasn't crusty. I've got the level between min and max. I'm running it with the egr unplugged if that makes any difference.
Old Mar 16, 2009 | 04:57 PM
jmaskew's Avatar
jmaskew
You may be leaking from the little rubber hose connector on the egr cooler. Climb up on top of your motor get close to the turbo and look down into the valley of the motor just in front of the turbo. The egr cooler is on the left side of the valley and if you have an old hose it will be orange or blue if it's a newer one. Use a flashlight to shine down in the valley and see if there is coolant visible.
Old Mar 16, 2009 | 05:07 PM
ruffneck22's Avatar
ruffneck22
sounds to me like maybe its your heater core. i'd have a look at that and maybe the connections to that.
Old Mar 16, 2009 | 05:19 PM
bismic's Avatar
bismic
+1 on that diagnosis
Old Mar 16, 2009 | 06:30 PM
69cj's Avatar
69cj
+ 2 here. If heater core is leaking it will usually leak inside the cab.
Old Mar 16, 2009 | 07:21 PM
Scottk250sd
Jmaskew/Stroked out - appears the egr cooler hose may be the culprit. There was no fresh fluid, but it did look like it was recently wet (hasn't leaked since Sunday morning).. I'll have to wait until it leaks again to be 100% sure - but I think you hit the nail on the head.. That hose looks like it could be a bear to get out of there - any hints on replacing that thing? Thanks for the help fellas.. Love the site already!!
Old Mar 16, 2009 | 07:52 PM
04F-250mark's Avatar
04F-250mark
Sorry if I'm late WELCOME TO FTE!
