stuck again
Old Dec 11, 2011 | 11:03 PM
Eastland's Avatar
Eastland
stuck again
ok have everything back together for the ball joints and now I am trying to put new rotors and pads on and one glide pin on each side does not want to move at all. what is the best way to get these unstuck? I have new pins to replace them but cant get these 2 out. could really use something quick been at this for over 10 hours and need to get to bed here soon.
thanks
Old Dec 11, 2011 | 11:23 PM
housedad's Avatar
housedad
It's not a pretty picture.
This is the best advice that I found on the net about the problem
"How did you get the frozen pins out of the calipers. So far I have 4 out of 6 that are stuck. (haven't gotten to the last one yet)
masheapy 7 months ago
Reply ShareRemoveFlag for spamBlock UserUnblock User
@masheapy keep on soaking them with penetrant i find PB Blaster works best, then grab the pins with a vice grip and try to work them free..... be careful on to booger them up too bad if you plan on reusing them, temporarily. Another thing i did with the vice grip was clamp it onto the pin and then whack the vice grip with a hammer in the direction to "pull the pins out'"
From this link in the comments section:
How to replace F-250 Brake Pads - YouTube
Heat, penetrant, etc.
Old Dec 11, 2011 | 11:25 PM
housedad's Avatar
housedad
Google these key works and there is a lot of posts on it.
stuck pin ford f250 caliper
Old Dec 12, 2011 | 05:59 AM
tdappleman's Avatar
tdappleman
I use Seafoam Deep Creep - but the thought is the same. If you have a torch, you can heat the bracket up slightly to have it expand which is usually enough to free the slide. Deep Creep is a little less flammable than other sprays but still be careful - especially with the rubber boot unless you have a replacement.
Old Dec 12, 2011 | 10:21 AM
Skinsfan6's Avatar
Skinsfan6
If you booger the pins up bad Napa carries replacements. I think they are listed under brake hardware or something. Clean and lube your old ones with brake lube before reinstalling if you keep them.
tangster
Jan 11, 2012 11:46 AM
KRUSTY51
Jul 28, 2010 12:50 AM
howler4x4
Jun 25, 2009 02:26 PM
xjcamaro89
2004 - 2008 F150
Feb 25, 2009 07:04 AM
spanky350
Sep 3, 2004 02:11 PM
