stuck caliper pin
Old Jun 23, 2009 | 10:14 PM
howler4x4's Avatar
howler4x4
stuck caliper pin
How to remove a stuck caliper pin?
Tried hammering it out with a punch, hammering it in, twisting, all w/ rust buster.
Heat? Propane or acetylene?
What should I expect when I try to remove the rotors?
TIA
Old Jun 23, 2009 | 11:11 PM
ReAX's Avatar
ReAX
A smoke wrench should help, but I would let kroil soak on it for a couple of hours to overnight if possible.
Old Jun 24, 2009 | 11:02 AM
Ruby's X's Avatar
Ruby's X
I had the same problem last week. Could not get the pins out! Do the safe thing and buy the caliper bracket and caliper pin hardware kit, about $115 for my front end, and know your going to stop!
Old Jun 24, 2009 | 02:25 PM
luxury's Avatar
luxury
TIA
If they're that hard to get out, they probably won't be usable anyways. I'd feel better replacing them with new and not worrying about them freezing up again in 6 months.
The rotors came off my Ex pretty easily. My Expy was another story - had to cut through them with a grinder and break them into pieces with a sledge to get them off!
Old Jun 24, 2009 | 05:21 PM
gr8scott72's Avatar
gr8scott72
Mine with 156k miles of rust free climate came out ok but about 2 weeks after greasing the pins up and putting it all back together, there was something wrong with the caliper and I was getting smoke out of the right front wheel well. I bought a Ford "loaded" caliper for $86 from Ryan Automotive and just replaced the whole thing. So far so good.
Old Jun 24, 2009 | 06:43 PM
RACERX7775's Avatar
RACERX7775
ahhh, me too. replaced the 4 rotors with art cryo ones and pads. i got the slotted and drilled. i went to pull the pins out, and the last wheel, left front, was completely seized. this was at 3:30 on an friday. had it in stock. thank god for that one. lists for $89. my cost was $63. already had all new brake hardware.
Old Jun 25, 2009 | 02:26 PM
howler4x4's Avatar
howler4x4
I welded a nut to the end of the pin. Impact gun got it loose ASAP
Rotors came off easily, 1 hit each.
I did buy all new pins & bolts at the local auto parts store, $9/ side.
I was lucky that the dealership was out of stock; the bolts were $9 each plus ~$24/side for the pin kits. $84 total
sanman1969
132
Apr 25, 2019 09:40 AM
packagerjr
May 2, 2017 02:07 PM
ProStreetDriver
General Automotive Discussion
May 14, 2016 12:31 AM
fiftyfordfloored
1997 - 2003 F150
20
Oct 25, 2010 09:45 AM
jmadsen
Aug 3, 2008 10:20 AM
