What's wrong now????
Old Dec 10, 2011 | 07:58 PM
BLADE35's Avatar
BLADE35
Originally Posted by weldworks54
Icp 3650 wot. 640's@ idle. Icr 25.3@ idle 68 wot. 20# boost @ wot Normal take off boost is @2.5@ 20 mph 4.0@40mph then it hangs out between 3-5# @ 60mph Yeah it an o3
well all these numbers look ok so far
HPO is good no leaks
Boost at 20 psi at WOT is a little low but not to bad would expect it to be worse if it leaked Veins might need a cleaning but shouldnt be the cause of your issues
Hows the FICM volts???
and alternator volts??
Hows the fuel pressure??
Old Dec 10, 2011 | 09:22 PM
9228.bobcat's Avatar
9228.bobcat
egr valve stuck open???? Maybe.
Old Dec 10, 2011 | 09:30 PM
bismic's Avatar
bismic
what are EBP, Baro, and MAP at KOEO?
Old Dec 11, 2011 | 06:06 AM
weldworks54's Avatar
weldworks54
Ficm is 49.5v drops to 48.5v on start up Alternater 13.8-14v. Bismic the. EBP has been discontinued on mine 2003 model BARO is 14.6 KOEO Map is 14.3
Old Dec 11, 2011 | 11:33 AM
BLADE35's Avatar
BLADE35
well dang those look good to
have you looked for a cracked ypipe or anything like that
Old Dec 11, 2011 | 11:44 AM
bismic's Avatar
bismic
Check for leaks in the MAP hose also.
Old Dec 11, 2011 | 05:51 PM
weldworks54
I got the fuel filters changed this evening and took her for a spin it seems to be running normal I guess 7000 miles between changes is too long for me. I guess that just adds another thing to do on my oil changes. I have noticed the blower only quits when I put the truck in 4x4?
Old Dec 11, 2011 | 05:59 PM
BLADE35's Avatar
BLADE35
Do you have the blue fuel pressure spring installed???
Old Dec 11, 2011 | 08:25 PM
Jack Scandia's Avatar
Jack Scandia
Defrost only
I had the same problem on my 06 and it was just a plug on pass. side near firewall wasnt snapped together tightly
Old Dec 12, 2011 | 06:38 AM
weldworks54
Yeah blade I got the blue spring but it still makes me wonder if I've hurt the injectors Jack. I'll get over there this even and see what I find
Old Dec 12, 2011 | 07:16 AM
bismic's Avatar
bismic
As I said - you have a vacuum leak.
The 4x4 solenoid is a common leak point (passenger fender wall area)
Old Dec 12, 2011 | 10:00 AM
weldworks54
Thanks Bismic I'll get over there and poke around this evening and see what I can find
Old Dec 14, 2011 | 04:13 PM
  #28
stupage's Avatar
stupage
I have added a spin on fuel filter between tank and filter, both to protect injectors and save on the $80 set of fuel filters from ford.
TinMan289
Jul 13, 2018 04:16 PM
Dezerch
Aug 26, 2017 08:07 AM
siciliannightmare
Sep 17, 2014 12:55 PM
sufferingant
Sep 23, 2010 07:57 PM
lewis racing
Jul 18, 2010 03:55 AM
