Watcha guys think?
Old Dec 14, 2011 | 06:00 PM
bobby84_00's Avatar
bobby84_00
Watcha guys think?
Ford 6.0 Powerstroke 2003 F250, Lifted 4x4
I really wana newer truck and this is one I've been looking at. The guy says the miles are mainly highway and hes had 0 6.0 issues with it. Says it runs hard, and never had a 5th wheel hitch in the bed or pulled any major loads. It's 4 hours away and I don't want to drive all that way if it's a waste. I know the 6.0 doesn't last as long (miles wise) as a 7.3 but what should I expect with these miles? Also, if I do buy it should I do the egr delete or leave it as is since its been fine so far? thanks!!
Old Dec 14, 2011 | 06:10 PM
bobby84_00's Avatar
bobby84_00
Also, the truck has had oil changes by ford every 5,000 miles and both fuel filters every 15,000.
Old Dec 14, 2011 | 06:20 PM
BLADE35's Avatar
BLADE35
You take care of that 6.0 Id betten she will go just as far as a 7.3
the Bottom end in these 6.0 is very very solid
trannys is very solid too.
If your really serios about a 6.0 get a scangauge to take with you for the test ride and check it out
other than that read thru this
Buying used 6.0
https://www.ford-trucks.com/forums/9...used-6-0l.html
SATX210
Jul 12, 2016 04:07 PM
SilentlySoaring
Aug 9, 2012 10:25 AM
fergi515
General Diesel Discussion
77
Feb 18, 2011 10:51 PM
gavlik711
Feb 4, 2007 12:44 PM
eric777
13
Jun 24, 2006 09:25 AM
