Sponsored by: Real Truck
Truck Leaning ??
Old Dec 5, 2011 | 05:11 PM
Trophy_23's Avatar
Trophy_23
Truck Leaning ??
Just was doing a little measuring today and noticed the truck is leaning to the left, there is a 1" difference (lower left side). I have a full tank would that do it? Any other suggestions?
Old Dec 5, 2011 | 05:24 PM
FordGuy85's Avatar
FordGuy85
A tank full of gas should not make the truck lean. I have a 38 gallon tank and have never noticed the truck leaning.
Old Dec 5, 2011 | 05:41 PM
Hotpocket's Avatar
Hotpocket
my truck ground to fender above wheel is 42 in driver front and 43 in pass front. 43.5 in driver rear and 44.5 pass rear
Old Dec 5, 2011 | 05:53 PM
SuperDutyScaler's Avatar
SuperDutyScaler
the driver side is prone to lean on the super duty's. ford said that up to 1" i think is ok, they sell a block kit for the driver side rear, ill try to find the original thread about it if i i can.
Old Dec 5, 2011 | 06:00 PM
SuperDutyScaler
https://www.ford-trucks.com/forums/3...sion-lean.html
for some reason this is the only one i could find, i hate this web sites search page.
Old Dec 5, 2011 | 07:03 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Here's a thread I posted on the subject a few years ago.
https://www.ford-trucks.com/forums/8...lean-shim.html
I ended up just living with it and its really not noticeable. I think a slick fix would be airbags though. Air them up differently to correct the sag. I haven't got there yet though.
Old Dec 5, 2011 | 08:51 PM
Trophy_23's Avatar
Trophy_23
Wow so its pretty common then by the sounds of it. I had never noticed until I was looking at my mudflaps and one looked shorter so I grabbed a tape, and they hang the same length from the fenderwell but one side is higher off the ground. Anyways I'll ask about it next time the truck is in, I am under extended warranty still so worth mentioning I guess.
Old Dec 6, 2011 | 02:48 AM
FordGuy85's Avatar
FordGuy85
Interesting info here! Gues i will be checking my 99 for this problem.
Old Dec 6, 2011 | 12:49 PM
SuperDutyScaler
trophy if you still have a warrenty i would take it to the dealer and have them install the shim. I installed a long add a leaf in the rear of my truck about three years ago and it hasnt moved yet, my rear is about 1/8 to 1/4 off on a given day depending on fuel tank.
Old Dec 6, 2011 | 02:10 PM
cartmanea's Avatar
cartmanea
I have 1-1.5" lean on my '03. Planning to swap rear springs eventually to see if it will even back out, I'd rather do that than shim it.
Old Dec 18, 2011 | 02:21 AM
Robert Stoner's Avatar
Robert Stoner
Hey Guys Im glad I found this post. I have a a 03 SD CC SB 4x4 w/ a 7.3. I had a 1 1/4 inches of sag on my front left side Measured about 5/8 of an inch on the left rear.
I installed some rough country springs( there leveling kit spring pack replacement) thinking replacing the worn out springs with fresh packs would fix my problem.And still Have a more then an inch of sag on the front left and same 5/8" in the rear. Is the rear sag going to cause that much of an Issue up front? The lean is driving me crazy to the point I cant stand to even look at the truck( And I really like my truck).
Kind of looking where to go next to fix my issue thanks in advance for any info.
nolszewski
17
May 16, 2018 08:28 AM
Paul T
Jan 16, 2015 05:26 PM
serviceguy
May 17, 2008 08:29 AM
natewoz
25
Feb 17, 2008 08:41 AM
Bear_Hunter
Apr 1, 2004 08:49 AM
