Gas Fill location
Old May 15, 2008 | 11:30 AM
serviceguy's Avatar
serviceguy
Gas Fill location
I have a box for the 78 that I am restoring I did not buy it the previous owner did it is in good shape, no rust, no dents. But the truck it came off of must have only had the rear tank and mine only has the mid ship tank. My question is could someone give me the dimensions for where it should be located. moving it is no problem for me I have done alot of fabrication in my day I just need to know where to put it.
Thanks
Old May 15, 2008 | 04:43 PM
Dr. Dirt's Avatar
Dr. Dirt
the rear tank should be in between the frame rails in the very back of the truck.
Old May 15, 2008 | 04:54 PM
fordophile's Avatar
fordophile
huh, think he might have been asking where to move the fill opening to.....but wouldn't you have the old box for that...? probably want to leave the rear opening in place and get one to graft from a junker....and/or add the rear tank- the truck should have come with it standard
Old May 15, 2008 | 06:15 PM
bucks77ford's Avatar
bucks77ford
Usually the midship tank is an auxillary and not the main tank. Your 78 should have had a rear tank as a main, unless someone took it out. Do you have an in-cab tank as well.
Old May 16, 2008 | 11:11 AM
serviceguy's Avatar
serviceguy
I don't have the old box to measure off of. This truck belonged to a friend of mine that pasted away he was in the middle of restoring it so what I got is alot of parts. All I need to know is where to locate the filler opening. The truck originally had both midship and rear tanks I don't plan to put the rear tank back in ever don't plan to drive it enough or very far from home to need two tanks.
Old May 16, 2008 | 01:27 PM
lostinfords's Avatar
lostinfords
You will spend less money and have less aggravation w/ just installing a rear fuel tank than trying to 'graft' in a fwd. fuel door. You can cheat and use the saddle tank filler neck which was inside the wheel well and just leave the rear fuel door as a 'dummy', just an option.
Old May 16, 2008 | 01:30 PM
lostinfords
Other note: the fwd. fuel door will be parallel w/ rear fuel door, and if your bed has the raised spot in the lower bottom edge of d/s bed, fwd. of wheel well you can get an idea where the access door will need to go.
Old May 16, 2008 | 02:17 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
This is just my opinion, but...
These trucks didn't come with just a front tank.
All of these trucks, (bar highboys, chassis cabs) came with a rear tank as standard.
I would put in the Rear tank, because it is the main tank on these trucks, and remove the auxilery or saddle tank, if you don't want two tanks.
This would eliminate all need for any fabrication work, and make finding replacement parts down the road, if needed, easier and not impossible to find.
As I said Just an Opinion.
Old May 16, 2008 | 02:29 PM
4x4 Bart's Avatar
4x4 Bart
Who has the money to fill more than one tank?
Old May 16, 2008 | 02:47 PM
lostinfords
I have a couple of trucks w/ 2 tanks, when the money is there and it ain't that often I fill 'em up before it goes up and it is quite some time before the next fill up, it actually seems like they never go empty, just keep toppin' them off, guess I actually need to start them sometime...lol.
Old May 16, 2008 | 03:04 PM
81-F-150-Explorer
This is what I do. I never let either tank get below half a tank anymore. This way I have the gas in an emergency, the tanks don't rust, and I don't get a big whopping $160 bill each time I fill up.
Old May 16, 2008 | 10:43 PM
bucks77ford
I also agree with putting in a rear tank. They are not that expensive and will save alot of work for ya.
Old May 17, 2008 | 08:29 AM
Jermafenser's Avatar
Jermafenser
I'd say put in the rear tank. You can find all parts for the rear tank; nary for the front.
blustang6614
Feb 27, 2015 10:58 PM
KG Excursion
Jun 27, 2014 07:59 AM
White 99
Dec 22, 2011 11:08 PM
bassfshr2
Sep 30, 2009 11:31 AM
gota0have0boost
Jan 4, 2007 08:37 PM
