Cleaning the pcm for a chip
Old Dec 2, 2011 | 08:48 AM
f1501987's Avatar
f1501987
Whats the best way to clean it? I took my pcm out and its got a lot of silicone on it like it says.
Old Dec 2, 2011 | 08:58 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Here are some instructions. Click on the F5 link near the bottom.
Riffraff Diesel Performance Parts: Diesel Performane Parts Installation Downloads | Up-pipe installation | Regulated Return Installation and more - Installation
Old Dec 2, 2011 | 11:01 AM
f1501987's Avatar
f1501987
Well I cleaned it and scratched off some on the tin, like 3 streaks from were I used my finger nail, But plugged it in the truck and the truck still starts, So any harm done to it you think? It looks pretty clean though
Old Dec 2, 2011 | 11:08 AM
PaysonPSD's Avatar
PaysonPSD
If that is with chip installed you should be ok. But if you haven't installed chip yet you won't no until then.
Old Dec 2, 2011 | 11:28 AM
f1501987's Avatar
f1501987
Yea haven't got the chip in the mail yet. So what can I do if it don't work? Spose to be here today or tomorrow around 2 pm.
Old Dec 2, 2011 | 12:10 PM
PaysonPSD's Avatar
PaysonPSD
If the chip fits tightly you shouldn't have a problem. Also be sure to tighten the PCM connector bolt after installing or you might have a no start. The bolt needs to be tight to ensure all the pins make good contact.
Old Dec 2, 2011 | 12:15 PM
f1501987's Avatar
f1501987
Will do, Ill post as soon as I get it installed in and try it. Thanks
Old Dec 2, 2011 | 12:56 PM
DemonRace6's Avatar
DemonRace6
Hi!
I got my chip in yesterday! I'll be cleaning my PCM and installing it on Sunday but wont be running it untill I get the injectors next week.
What did you do that scratched it?
Old Dec 2, 2011 | 01:02 PM
f1501987's Avatar
f1501987
Used my finger nail to clean it off. After I realized it scratched I used acetone to clean it and it don't really look that bad. Like the guy said as long as it fits snug it should be ok I hope
Old Dec 2, 2011 | 03:15 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Joe,
I used a brass bristle brush (sorta like a tooth brush) and it worked excellent. You can find them at your hardware store or even Harbor Freight Tools. The brass removes the silicone but doesn't really attack the tin too much so you might want to give that a try first. Here is the general procedure that I used...
I put on a dark T-shirt (dark red, black etc).
Then I removed the PCM per usual instructions and then opened it up to expose the circuit board. While holding the circuit board in the palm of my hand (with my elbow tucked to my ribs)...I brushed the silicone off the contacts with the brass brush (brushing towards my chest). If you are wearing a dark shirt, you will see the tiny bits of silicone collect on the shirt. It will only take 6-10 brushes and you will notice that no more silicone is landing on your shirt.
Turn the board over and do the other side the same way.
Now, look in between the contacts and use a toothpick to remove any remaining silicone that is BETWEEN the contacts.
At this point the contacts might still appear somewhat shiny or glossy. Use the scotchbrite pad to lightly buff the contacts until the tin appears dull (or a matte finish). Stop when you knock off the glossy finish because that means all the silicone is gone.
At this point your chip should fit snugly and make positive contact.
This seemed to work great for my truck so hopefully it will help you out as well.
Old Dec 2, 2011 | 03:47 PM
HH60FE's Avatar
HH60FE
and tape the bejesus out of it once you get it connected. Don't want the connector to move.
Old Dec 3, 2011 | 02:55 PM
f1501987's Avatar
f1501987
Well got my chip in today Just got done testing driving it. I'm very impressed with it from going to it from a edge programmer. Had a problem the first time, connectors wasn't clean enough so cleaned it again and used the pad it came with worked real well.
maximusfd
Aug 5, 2013 06:52 PM
89broncoll
20
Nov 14, 2011 08:55 PM
brooksbronco17
Mar 3, 2010 08:48 PM
avi
Aug 4, 2007 07:46 AM
mtgrzlyman
Mar 11, 2006 09:43 AM
