6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Bought an '08 Throwing a Code
Old Dec 1, 2011 | 09:23 AM
RIDETHE's Avatar
RIDETHE
After contemplating for a long time, I finally bought myself an '08 F250, but it came with a check engine light. It also gets very erratic gas mileage (ranges from 13.5-17 under the same highway driving conditions) and I catch a whiff of smoke once in awhile sitting in traffic. It's throwing P2031, P2032, and P2084 which indicates a very high temp reading (low voltage). It sounds like this is just a bad EGT sensor at Bank 1 Sensor 2. Does anyone know where this is located? I believe it's the one between CAT and DPF, but I'm not sure. Any help is greatly appreciated.
Old Dec 1, 2011 | 09:36 AM
senix's Avatar
senix
EGT2 is the sensor
I'd take it in and have them do it...or call for an estimate. I bet it will break trying to get it out.
That is the one that is usually the problem. Did you look at the wiring to see if it was in order?
Old Dec 1, 2011 | 09:41 AM
RIDETHE's Avatar
RIDETHE
The wiring looks alright. Plug is in and tight, but I didn't really look too closely for frays or rubs in the harness. I'd rather it be the $55 sensor than having to track down a shorted wire.
Old Dec 1, 2011 | 09:42 AM
senix's Avatar
senix
I agree with you on the wiring issue! I hate electrical!
Old Dec 1, 2011 | 09:59 AM
RIDETHE's Avatar
RIDETHE
I have a Minimaxx and DPF/Cat delete in the mail. Will the Minimaxx let me just delete the sensor?
Old Dec 1, 2011 | 10:03 AM
senix's Avatar
senix
I don't know enough about the mini to answer that. Best to check with them.
Old Dec 1, 2011 | 04:23 PM
RIDETHE's Avatar
RIDETHE
Replaced the sensor right after the cat, Check engine light didn't go out at first, but it did after a few starts.
Old Dec 1, 2011 | 07:58 PM
senix's Avatar
senix
great! I was concerned it would not want to come out.
Headviking
Feb 8, 2019 08:56 PM
Golflug
2015 - 2020 F150
Dec 28, 2016 08:09 PM
TheDuke
May 25, 2015 07:45 AM
Storm
3.8 & 4.2L V6
May 13, 2006 02:55 PM
scouterspokane
Apr 28, 2006 03:34 PM
