Autometer Pryometer quit working
Old Dec 1, 2011 | 08:41 AM
bbarton's Avatar
bbarton
I have an Autometer Pyrometer in my truck (2002 F350 CC DRW 7.3L)and it's worked great for many years but recently it's started acting a bit sporadic. Sometimes it reads the temp correctly, but occasionally it'll get stuck either on Zero or at some other point .... usually around 1100 degrees if I've been accelerating.
Sometimes I can tap the gauge and it'll start working again, but usually not.
Before delving into this problem, I wanted to ask you guys where to start. My first thought when it happened was that the exhaust probe was going bad since it's exposed to the extreme temp differences, but the tapping of the gauge tends to make me think a needle is sticking int he gauge.
Has anyone run across this kind of problem before? Any suggestions on where to start? Picture below was taken after driving about 20 mins this morning while stopped at a traffic light. Tapping the gauge had no effect.
Old Dec 1, 2011 | 04:05 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Dec 1, 2011 | 04:36 PM
Centauro97's Avatar
Centauro97
If tapping on it makes a difference then the problem is in the gauge.
It's mechanical, it'll wear out. I doubt it's the box.
If it sticks at zero there may be a loose connection, but sticking at higher numbers points to gauge problem.
Could be more than one issue. You'll need to pull it either way so depends on how much time versus money you're willing to spend.
Old Dec 1, 2011 | 08:51 PM
Bonanza35's Avatar
Bonanza35
Let us know what you do. I have the same gauge, its been great for three years now.
Chet
Old Dec 2, 2011 | 06:45 AM
Tugly's Avatar
Tugly
There's a lot of vibration in our rides, and this wreaks havoc on electrical connections. I'd test every connection (pull/jiggle test), starting with the easiest first. I have also seen connectors "gum up" and simply disconnecting/reconnecting a few time cleans the contact points and things work again. This is one of my "magic tricks" as a tech to get things going fast, but I still like to find out why the contacts gum up and do something about it - if possible. Are all your electrical connections outside the cab protected from the elements?
Old Dec 2, 2011 | 07:14 AM
Ponyboychris's Avatar
Ponyboychris
Mine is starting to do the same thing (UltaLite series). I emailed the customer service rep at Autometer and they said that I can send it to them for a free check and if they find something wrong, they will contact me to explain if there are costs involved to fix it. I still haven't boxed it up and sent it off yet but I going to soon.
Old Dec 2, 2011 | 08:42 AM
JamesHajek's Avatar
JamesHajek
Where is your ground? Do all your gauges share a ground?
My pyro did that about 6 months ago, I took the ground wire for the EGT and isolated it. That seemed to do the trick... Autometer told me it's rarely the gauge, normally a connection issue...
Old Dec 2, 2011 | 05:19 PM
Ponyboychris
Yes, good place to start. For mine, it's the gauge.
WatsonR
Dec 17, 2015 11:26 PM
Steves55
Apr 29, 2011 10:18 PM
pitrow
Jul 10, 2007 04:44 PM
F350SD
Jan 3, 2007 10:04 PM
racenitro
Jan 29, 2005 08:38 PM
