faulty outside temp
Old Jul 10, 2007 | 04:15 PM
pitrow's Avatar
pitrow
faulty outside temp
OK, the outside temperature gauge on my Expy has been acting up for a while, so I thought I'd ask y'all if you have any suggestions.
First off, the gauge is usually pretty accurate and within a couple degrees of where it should be. However when the temperature starts climbing the gauge quits working. For example today the mercury is quickly headed north of the century mark and the gauge is stuck on 76 degrees outside. Which I know is way wrong.
I haven't been able to figure out the exact temperature it quits at yet but it seems to be somewhere around 85 or so. Once it gets warmer than that the gauge reverts to 76 and stays there. When it cools down, then it starts working fine again.
Any ideas?
Old Jul 10, 2007 | 04:44 PM
sledneck97's Avatar
sledneck97
I had the same problem a few weeks back. I just replaced the sensor and it fixed the problem.
https://www.ford-trucks.com/forums/6...s-too-low.html
MemphisSenior
General Automotive Discussion
Feb 18, 2008 03:01 PM
sledneck97
1997 - 2003 F150
Jun 9, 2007 12:56 PM
Genesdsu
2004 - 2008 F150
May 16, 2005 09:22 PM
InboundFX4
2004 - 2008 F150
Sep 3, 2004 01:14 AM
