Fire wall padding
Old Nov 30, 2011 | 01:43 PM
john fin's Avatar
john fin
Fire wall padding
I was thinking of replacing my corrugated cardboard backing with 1/2" thick jute (carpet) backing. Any problems with that?
Old Nov 30, 2011 | 04:55 PM
jniolon's Avatar
jniolon
old and in the way
going all show car trailer queen, eh john ???
john
Old Nov 30, 2011 | 06:34 PM
john fin's Avatar
john fin
padding
No trailer queen, just a purist. Putting it back together as close to original as I can. I think Bobs farmer non-truck loving in-laws owned this truck at one time.
Old Nov 30, 2011 | 08:38 PM
arrowheadfred's Avatar
arrowheadfred
classic haulers has a insulated ABS innner firewall pad. Fits perfect.
Old Dec 1, 2011 | 09:15 AM
john fin's Avatar
john fin
$175??? I only paid $200 for my whole truck. My backing piece is ok, just the cardboard insulation is bad.
Old Dec 1, 2011 | 09:22 AM
ALBUQ F-1's Avatar
ALBUQ F-1
What "backing piece"? Mine has cardboard, nothing else. Jute is great for holding water against the steel.
So are you going to use that $200 criteria for everything? Sounds like Rustoleum is in your future for paint?! You surely have several times that just in your engine rebuild and trans.
Old Dec 1, 2011 | 11:11 AM
CharlieLed's Avatar
CharlieLed
Closed cell foam (CCF) is better...more noise/heat isolation and it does not hold water.
Old Dec 1, 2011 | 11:12 AM
tip49's Avatar
tip49
Firewall cover
My cover was in bad shape, so I removed it and used it as a template to form a new one from 6 mm PVC. I used heat gun to shape it by placing the old one underneath with 2 x 4's under the raised portion. I used a 1/4" heat blanket that is covered with foil as my insulation. I marked all the screw holes, etc from the original. You have to "burn" throught the PVC liner for the holes due to the liner balling up in the drill. I used plumbing pipe and an awl heated with butane torch. Not perfect but I tweaked the fit once I started to install on firewall.
Tom
Old Dec 1, 2011 | 11:45 AM
john fin's Avatar
john fin
That piece turned out well. My original insulation piece was corrugated cardbard and after 65 years it was dry so I am not worried about moisture. The accellerator bracket mounting is setup for the thick padding. It has 1/2" hat washers.
Old Dec 1, 2011 | 03:25 PM
Doc's Avatar
Doc
If it has a cowl vent and a windshield, you NEED to worry about moisture. How's the firewall and floor pans? Any extra holes there?
Snowseeker
Jan 8, 2014 08:34 PM
CharlieLed
23
Aug 5, 2013 10:21 PM
akalogan
Jul 22, 2011 07:06 PM
DAVID'S97F250HD
Oct 4, 2010 08:44 PM
aurgathor
All Things Towing
Oct 22, 2007 04:44 PM
