Block Heater
Old Nov 27, 2011 | 11:26 AM
CAPTAIN DIESEL's Avatar
CAPTAIN DIESEL
Block Heater
I removed it and its cord.....and installed a hose faucet in its place case i get thirsty on long trips Or ya can just use it as a drain
Old Nov 27, 2011 | 02:18 PM
HD Rider's Avatar
HD Rider
If I did that, I would never be able to drive my truck in the winter. It will start without the block heater down to -13 but no colder. Temps below -20 are common here.
Old Nov 27, 2011 | 03:30 PM
CAPTAIN DIESEL
Deff dont get that cold here in jersey so i dont need it.
Old Nov 27, 2011 | 06:37 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Sooooooo... What was the point? why not just leave it there. Was it doing any harm? no.
Old Nov 27, 2011 | 06:52 PM
nlemerise's Avatar
nlemerise
Originally Posted by A/Ox4
Sooooooo... What was the point?.
I assumed to save weight
Old Nov 27, 2011 | 07:01 PM
CAPTAIN DIESEL
I wanted to clean up the area as well as avoid a future leak from the area..and better coolant flow to the oil cooler as the actual heat element is 1 inch wide and sticks 4 inch in. Its also nice to have another drain other then the plactic one on the bottom of rad, the hose faucet can also be used to flush the system.
Old Nov 27, 2011 | 10:56 PM
JonathanN's Avatar
JonathanN
Have to say that the thought of using it for a flush is pretty cool. It doesn't get that cold here, either but it'll be nice when the GP's get weak but not enough for you to really want to have to tear the truck down to replace them. Either way, great info. What size threads were in the block as well as on the faucet? Any reducers needed?
Old Nov 27, 2011 | 11:14 PM
CAPTAIN DIESEL
Regular 3/4 pipe thread.
Old Nov 27, 2011 | 11:16 PM
CAPTAIN DIESEL
You dont need a reducer unless you want to use a 1/2 hose faucet.
mudguts
Nov 21, 2015 04:30 PM
smithrock
Dec 9, 2011 03:37 PM
JonArmy
Nov 19, 2011 06:16 PM
cOpE!
Montana Chapter
Oct 29, 2010 04:46 PM
97 RED PSD
Dec 9, 2005 04:52 PM
