AE won't connect
Old Nov 26, 2011 | 03:16 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
AE won't connect
I set up the Ae with my vehicle(99 ford powerstroke 7.3). It won't connect to the truck with the key on. Didn't try it with it running. All i can read when it does connect(only twice)is mph,rpm,and intake man absolute psi. When it's running and i put in the vin # the truck dies. Read through the instr,tried changing things to no luck. Did I miss something?
Old Nov 26, 2011 | 06:50 PM
cord812's Avatar
cord812
I too have been learning my new AE.. check your fuses ..I assume you have ford enhanced and make sure it is displayed, make sure you have the ford setup.
don't use the get VIN..it will shut you down..if you leave the ignition on too long it will dump fuel in combustion chamber too...so crank your truck up and warm it up a little.
my truck was produced 11/98..google AE there are a lot of reading...we are on the same level..plus I am working on my Nissan Titan
If no luck call Autoenginuity direct and talk to a tech..they were a big help to me
good luck..have your serial # on your connector..they will ask for it
Old Nov 26, 2011 | 11:48 PM
woodnthings's Avatar
woodnthings
Sounds like you did not activate the Ford Enhanced option.
Take a look at these instructions from Riffraff Diesel on how to set-up AE.
http://www.riffraffdiesel.com/mm5/RE...%20Install.pdf
Once you get it up and running, Feel free to use my Autoenginuity page to help with specific tests.
https://sites.google.com/site/woodnt.../autoenginuity
Old Nov 27, 2011 | 01:43 AM
diesel-fitter-bum01
I did all that Ken,and your page is saved on my pc already. Shows activated,and if it does connect I only get the three options to read.
Old Nov 27, 2011 | 10:33 AM
woodnthings
If you are only getting three options you are in the basic OBD II and not the enhanced package.
Did you set up the communications configuration with the J1850PWM And OBD II.
Here is another post where similar issues were had. https://www.ford-trucks.com/forums/1...questions.html
Old Nov 27, 2011 | 11:07 AM
diesel-fitter-bum01
I tried both ways. I haven't seen the green light come on the obdII connector. Just the red n yellow. I will check the fuses,but both my 12v services work. ?? I will keep trying things.
Old Nov 27, 2011 | 11:32 AM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Do you have PowerStroke 7.3L and Enhanced Powertrain selected?
Old Nov 27, 2011 | 01:01 PM
diesel-fitter-bum01
Yup,looked exactly like that. It can't find the obdII port. But it has connected twice allowing me to read rpm,mph,and map. Do I need to pull the chip?
Old Nov 27, 2011 | 11:07 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
I have never had AE not connect with the DP Tuner installed.
Check pin 16 on the OBDII port for 12 volts. If there's no voltage check the fuse for the cig lighter, #3 20A under dash.
Old Nov 28, 2011 | 08:28 AM
diesel-fitter-bum01
Went through that process yesterday. I'm trying it on the truck with the ts chip. I'm going to try the Ex when I get off work today. Thanks for all the help so far guys.
Stephenj148
Jan 22, 2013 11:02 AM
davbeisner
Dec 19, 2012 06:07 PM
NinerBikes
6.7L Power Stroke Diesel
76
Oct 20, 2011 10:01 PM
jeronlines
Jan 6, 2011 10:21 AM
HKusp
Jul 31, 2007 10:24 PM
