That's TCC, not ICC. The slippage code is a result of the solenoid circuit being bad. It's safe to drive it home as long as you're not towing. The trans will run hotter than normal because the converter isn't locked, but as long as you're not at max load it will be fine.
I went ahead and drove the truck the 1100 miles home without a problem. Everything functioned normal except slightly harsh shifts.Marks advise saved me a lot of money and time, thanks again.
