What is 3G?
Old Nov 16, 2011 | 01:15 PM
shotgun2's Avatar
shotgun2
What is 3G?
All right I will ask.
All kind of post make reference to a 3G swap.
I know it's an alternator, I just bought a new OEM one for my 78 F100 (300 six)
What makes it so special,
some post reference they got theirs from "sable" and other car?
From what year, is an alternator consider 3G.
does it matter car or truck.?
G
Old Nov 16, 2011 | 01:26 PM
Death85e's Avatar
Death85e
The short of it is a 3G swap is a 130 amp alt removed from a 96 mecury sable that takes very little to make work in our trucks. When done you will have better charging capacity on your truck as well as better power to operate existing lighting and some extra to run any additional lighting or power consuming devices such as big stereos. winches etc.
Old Nov 16, 2011 | 01:27 PM
shotgun2's Avatar
shotgun2
can you only get it out of the sable? or will a taurus do?
any other brand??
Old Nov 16, 2011 | 01:32 PM
Death85e's Avatar
Death85e
Ford tauras, mustang, sable, are the ones i know of right of hand.....give some of the guys time on here and they will be able to fill you in on exactly what years to use and what models you can get them from. In the mean time search 3G Upgrade in the seach feature at the top of the page and be prepared for alot of reading with some fantastic pics.
Old Nov 16, 2011 | 01:35 PM
HIO Silver's Avatar
HIO Silver
'just bumped to the top the mega-long 3g thread with potential donors for the new guys and gals.
Old Nov 16, 2011 | 06:31 PM
yankeerebel's Avatar
yankeerebel
I'm pretty sure "3G" is nothing more than slang for Third Generation.
Old Nov 16, 2011 | 09:57 PM
Thunderjet4x4's Avatar
Thunderjet4x4
3G is third generation alternators, as far as I know. 1G were the external regulated alternators from sometime in the 60's (not positive), 2G are the IAR:internal regulator from early 80's to mid 90's?
and the 3G is still in production today, I believe.
I think the 3G is the best, google it and figure it out. The cooling fan is inside the housing so it looks very tidy, without that damn external fan which gets sandblasted, and can crack.
The 3G is super easy to hook up, and outperforms them old chevy 1 wire alts.
The 3G has 2 models;
95amp 135mm diameter case. *4 holes(I will explain)
130 amp 148mm diameter case. *2 holes;
*The holes are cast into the front face of the alternator, between ribs, behind the pulley. Since there is no external fan, they can be seen easily.
There are variances, so google it or ask.
Old Nov 17, 2011 | 12:59 PM
shotgun2's Avatar
shotgun2
thanks
i tried using the search engine in here.
3g = no reply to short.
3g instalation = everything intalled....
3g modification = everything modified.....
3g conversion = everyting converted.....
I asked Carquest for a 3G alternator for a 78 F100, the girl look at me like I had antenna.
what i am after is, what model and year to I give her, so i can buy an alternator that i can convert my truck, I will work out the pulley and bracket from the scrap yard..
Thanks
G
Old Nov 17, 2011 | 01:07 PM
HIO Silver's Avatar
HIO Silver
Exclamation
Originally Posted by shotgun2
thanks
Here you go:
130G Alternators:
94-96 Mustang 3.8 V-6
94-95 Mustang 5.0
94-96 Thunderbird 3.8 V-6 (non SC)
95-96 Windstar 3.0 V-6 (most are 3.8's)
93-96 E/F series Trucks/Vans 4.9 L6*
96 Sable 3.0 V-6
94-96 Cougar 3.8 V-6
..AND READ THIS THREAD!!!! : https://www.ford-trucks.com/forums/9...g-upgrade.html
It contains wiring diagrams, pictures, and lots of input from your fellow FTE members on the 3G retrofit.
Old Nov 18, 2011 | 12:40 PM
shotgun2's Avatar
shotgun2
I checked with carquest today. (in canada)
$398 for a sable 96 alternator.
So in plain english, back to the scrap yard.
G
Old Nov 18, 2011 | 01:09 PM
psquare7575's Avatar
psquare7575
Will this guy ship to Canada?
I've bought from him several times.. Alternator is in my 78 Cougar.
RJM Injection Tech — Alternators
Already pre-clocked ready to bolt in
Old Nov 18, 2011 | 07:32 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
There are 2G externally regulated alternators as well.
There are a total of 5 Ford alternators. 1G, 2G, 3G, 4G and 6G.
4G is usually for dual alternator set-ups, but is also found in many Powerstroke 7.3 applications. The 6G is mostly a Superduty alternator.
Josh
Evan_P
134
Nov 21, 2019 12:43 AM
Jetcopterpilot
Mar 1, 2011 12:33 PM
SideWinder4.9l
Jun 22, 2009 12:45 AM
superbepro
Sep 12, 2005 06:10 AM
tsokorai
16
Jun 3, 2003 02:53 PM
