Winter cold starting issues
Old Nov 15, 2011 | 11:53 AM
graeaglecrawler's Avatar
graeaglecrawler
I live in the snow country of N. CA and have been having hard starting on cold mornings. It takes alittle longer to crank anthen gets running after a little stumble. Is there a cold start system or injector that makes the fuel richer until the engine heats up. If not, any ideas on what to check? '99 expy, 258k 5.4, thanks
Old Nov 15, 2011 | 04:05 PM
alloro's Avatar
alloro
I'd start by either testing or just replacing the coolant temperature sensor. If this is off and not interpreting the temperature correctly, the the PCM does not richen the mixture as required for a cold start.
F33lmywrath
Sep 18, 2016 09:42 AM
Restlesswildman
Dec 8, 2013 11:13 PM
nexeslee95
Feb 14, 2011 07:29 PM
ericg70
Feb 5, 2007 04:59 PM
bkles
Jan 5, 2004 02:44 PM
