new truck small problem
Old Nov 12, 2011 | 06:12 PM
logger250's Avatar
logger250
Just bought new truck 2001 7.3 transmission does not seam to kick down from d unless you manually shift into 2 also after about 20 secounds of start up the of light starts flashing please help.
Old Nov 12, 2011 | 06:17 PM
timmyboy76's Avatar
timmyboy76
"search" tab for OD light flashing...you'll get tons of hits here about that...short in a wire, in the steering column
Old Nov 12, 2011 | 06:21 PM
Sheldon Plankton's Avatar
Sheldon Plankton
The flashing light means there are stored trouble codes for the trans. You need to get the codes pulled and go from there. In the meantime, make sure the fluid level is OK. I don't want to alarm you, but if you literally "just" bought it do you have recourse with the seller? Large or small, you may be in for a repair bill.
Old Nov 12, 2011 | 06:25 PM
Sheldon Plankton
The notorious steering column short blows a fuse and takes out the instrument cluster and throttle. It happened to me. If I understand the OP correctly, that's not his problem.
Old Nov 12, 2011 | 09:00 PM
logger250's Avatar
logger250
Arhhh nooooo
Maddy
Nov 18, 2015 01:42 PM
patsalters
Sep 11, 2013 09:43 AM
johnymcfudge
32
Aug 16, 2012 02:54 PM
finitetime
18
Apr 11, 2012 06:55 PM
BroncoMad
Dec 31, 2007 10:38 PM
