Overdrive light
Old Sep 11, 2013 | 07:47 AM
patsalters's Avatar
patsalters
Overdrive light
My overdrive light started blinking on and off. It still shifts in and out of overdrive with the button, however the light continues to blink. What does this mean? I have to use the truck today to drive 400 miles and will not be able to service it until tomorrow. Is this a risk?
Old Sep 11, 2013 | 08:41 AM
Supercab's Avatar
Supercab
-Some say its caused by a bas vss sensor on the rear end that causes this, some say its a chaffed wire in the steering column.
Mine does this from time to time despite replacing the vss with a QUALITY one from NAPA as recommended here....most say the oem ones are not as good as the NAPA replacement.
You might try turning the engine off and re-starting it-when mine does this this is what I do amd I'm good for quite a while.
You might also try unplugging the wire from the sensor on top of the rear end housing and use ELECTRICAL PARTS CLEANER LIBERALLY on it as well....
Just trying to help get ya on the road..........mine shifts a little weird when the light is blinking...
Old Sep 11, 2013 | 09:42 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Then there are those of us who really know why it's blinking. It is blinking because there is a problem with the transmission system. The PCM has set a code to tell the tech what's wrong. The light blinks to alert the driver that there is a problem and a code is stored. It could be the VSS, or about 50 other things, too. It almost certainly is not a chafed wire in the steering column.
In order to find out what's wrong you need to get the codes read. The places that read codes free CANNOT read these codes. You'll need to pay an independent shop or a Ford dealer to read them for you.
As for driving it 400 mile like this, it may not cause a problem or it may destroy the transmission. The ONLY way to know is to get the codes read.
Old Sep 11, 2013 | 09:43 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Take it somewhere to pull the codes, no telling what it is until the codes are read.
haha Mark beat me to it.
turbo930ss
13
May 17, 2013 12:36 PM
drembedded
22
Aug 17, 2011 09:43 AM
bjis
Apr 5, 2010 10:09 PM
bravespear23
Nov 7, 2005 10:42 PM
Highmark18
Jul 16, 2005 11:10 PM
