Overdrive light blinking
Old Nov 18, 2015 | 01:01 PM
Maddy's Avatar
Maddy
I drive an 03 350 7.3. Overdrive light blinking only thing I noticed was the OD would not engage. Did it once while towing. What's the issue?
Old Nov 18, 2015 | 01:12 PM
Absolute's Avatar
Absolute
Usually the wires on the column for the switch get chafed and ground out. Real thin wires and plug right on top. They used to sell parts, but now its the whole shift lever, switch and everything. Up here its about 90 bucks. Probably cheaper down there. Easy repair, no special tools required.
Old Nov 18, 2015 | 01:38 PM
Pikachu's Avatar
Pikachu
You need to have the codes pulled. It's nothing but a wild guess without knowing what codes are set.
Old Nov 18, 2015 | 01:42 PM
milehi_350's Avatar
milehi_350
This happened to my truck. Easy fix. If you have no other symptoms than that's probably it. It's really easy to see if you take the steering column cover off. If you have shifting issues you'll need to check for codes.
Tmurphy38
Nov 13, 2016 08:35 PM
93MARKIII
Mar 6, 2010 08:39 AM
jutahh1
Dec 30, 2006 10:05 AM
mtgrzlyman
May 31, 2005 12:53 PM
snagtooth
1997 - 2003 F150
Jun 28, 2004 04:18 PM
