Steering Column
Old Nov 12, 2011 | 06:11 PM
kilich's Avatar
kilich
Steering Column
I have a 1976 F250 Highboy.. The bearings are bad in the steering column in my truck and i was wondering if a 1978 Steering column would fit because i found a good one at the local JYard
Old Nov 12, 2011 | 11:17 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I do believe it will bolt right in, but you could have a electrical connector issue at the main connector. I believe they were one way up to mid 77 and changed in 78?
If you are staying with the old harness, you will have to disassemble the connector (pull wire pins) to get the ol harness out of the column.
Old Nov 12, 2011 | 11:22 PM
kilich's Avatar
kilich
Dang.. Alright ill take a look at them. Thanks.
Old Nov 13, 2011 | 01:41 AM
F-250 restorer's Avatar
F-250 restorer
I would do a search in this forum. I'm sure you'll find the info you need. Someone has done it before and posted about it, surely.
Old Nov 13, 2011 | 09:07 AM
lostinfords's Avatar
lostinfords
If you can't locate one local or the 78/79 won't work let me know...I have one available in NJ from a 74 and a 2nd from a 77
Old Nov 13, 2011 | 09:20 AM
kilich's Avatar
kilich
How much you looking at selling one for? shipped to 48170
Old Nov 13, 2011 | 08:35 PM
lostinfords
pm sent...
Old Nov 13, 2011 | 09:19 PM
kingford72's Avatar
kingford72
Remember the lengths are different for a power steering column and manual steering column (2.??? inches longer). There is a difference in turn signal connectors but I don't know when they switched either.
Old Nov 13, 2011 | 09:24 PM
lostinfords
Are the guts the same?...as in the bearings/bushings...auto vs. manual columns?
Old Nov 13, 2011 | 09:26 PM
kingford72's Avatar
kingford72
I would imagine so but I never tried to swap parts.
Old Nov 13, 2011 | 11:08 PM
77&79F250's Avatar
77&79F250
73-mid 77 had some difference's in the wiring bundle, and the big plug at the bottom of the column. To use the old wiring you have to pull the pins and take the large connector off to get the wires out.
All from what I understand from FTE.....
cej123073
Jun 22, 2018 06:59 PM
brutus67
Mar 22, 2016 06:48 PM
oldblue31
Sep 20, 2006 10:17 PM
zippar
Jan 5, 2005 05:21 PM
360ranger74
Mar 13, 2004 12:16 PM
