smoke?
Old Nov 13, 2011 | 10:30 PM
Atwiss's Avatar
Atwiss
smoke?
i have a 1976 ford f150 4x4 with a 400 out of a 77 ltd, (true dual exhaust) and recently there has been smoke coming out of the driver side pipe what would cause this? im not sure if this has anything to do with the engine or the tranny(4speed) but it shakes between "idle" and high rpm no idea could it be a push rod and also on the same pipe there is black liquid coming out to
Old Nov 13, 2011 | 11:07 PM
jgavac's Avatar
jgavac
What color is the smoke? Does it smell like anything? If there is black liquid, then it might be oil.
Old Nov 13, 2011 | 11:25 PM
Atwiss's Avatar
Atwiss
its blueish black and im not to sure what it smells like........
Old Nov 13, 2011 | 11:30 PM
jgavac's Avatar
jgavac
Blue smoke and black liquid? All signs are pointing to a oil leak. Check your oil level, and see if it has gone down since your last check
SwOkcOffRoader's Avatar
SwOkcOffRoader
Do a compression test, then do a leak down test on any cylinders with low numbers. If it passes those, then it's either valve guides or a bad intake gasket. I had a 460 that smoked, everyone said rings, but after passing a compression test with flying colors, I pulled the intake and two cylinders were sucking oil out of the lifter valley.
Old Nov 13, 2011 | 11:39 PM
Atwiss's Avatar
Atwiss
im hoping it is a seal or something gonna try and do a compression test sometime this week but might have another engine i found in the paper its another 400 though
breedo99
Aug 17, 2015 02:23 AM
sjs28
16
Mar 29, 2015 09:08 AM
jkilduff
1997 - 2003 F150
May 27, 2010 05:15 PM
tylstruck
Apr 27, 2008 07:37 PM
t.j.g.
19
Jun 29, 2005 02:26 PM
