Steering column Interchange
Old Mar 5, 2004 | 04:21 PM
360ranger74's Avatar
360ranger74
Question hmm.... wonderin bout steering columns
hey all...just took out my steering column to replace it because of the dash fire i got when i bought (ole red)from the bare wiring....took out the harness (takin things out just kept goin)...
Was wondering if anything would practically fall in too place or if i need to get another of the same type....it's a 74 column auto???
Old Mar 5, 2004 | 09:01 PM
76supercab2's Avatar
76supercab2
I think 73 -76 are the same.
Old Mar 12, 2004 | 09:28 PM
360ranger74
tilt steering in a 74 auto. 4x2....is it difficult???
posted a thread the other day wonderin bout steering columns.....
never really got any replies.....just one ( thanx )
Was wonderin if anybody else had any information on the subject. Any help would be appreciated...
Old Mar 12, 2004 | 11:48 PM
Mil1ion's Avatar
Mil1ion
There are tons of threads on this forum regarding steering column swaps.
Maybe try the search feature as I don't have time to search for you.
Look along the top of the page and click Search.
Old Mar 13, 2004 | 06:51 AM
docholiday72tx's Avatar
docholiday72tx
Hey 360ranger, I learned all about the collums when I switched from standard to automatic. 73 to 76 will interchange. You need to be careful as far as power or manual steering. there is a little plate that bolts to the firewall from the engine side that helps hold the rubber gasket for the collum. That plate will be marked power or manual. The letters are probably about 1/2 an inch tall and etched in. They are a little hard to see with the plate in the truck. I have been told that the little plate that is welded to the bottom of the collum that holds it up to the bottom of the dash can be ground off moved and rewelded to make the power and manual collums interchange, but I did not actualy try that. I went to the wreckers and bout a collum for automatic with power and just bolted it right in. Expect to pay about 100 to 125 for a good collum and about 30 minutes to put it in. While you are putting it in, i would recomend changing the little rubber piece between the collum and the steering gear box. That piece was either 6 or 7 dollars at carquest. Let me know if I can answer anything else.
Old Mar 13, 2004 | 12:16 PM
mk's Avatar
mk
You can use any 73-79 column. Tilt was an option in 78-9 and will fit if you've got p/s.
mike
