Rear Disc Brake?
Old Nov 8, 2011 | 07:36 PM
74ford4x4's Avatar
74ford4x4
Rear Disc Brake?
I installed rear disc brakes, My question is do you leave the distribution block in and add a adjustable pro valve? Or do remove the distribution block and just run the pro valve? Ive read on pirate4x4 to remove dist. block and just run MC lines direct with adjustable valve . Thanks for any help
Old Nov 8, 2011 | 08:48 PM
HIO Silver's Avatar
HIO Silver
It's your call whether to leave it in or take it out.
The distribution block doesn't do any metering. You can leave it in and simply plumb the adjustable prop. valve into the rear brake circuit.
Old Nov 8, 2011 | 09:09 PM
Scifi266's Avatar
Scifi266
if you had a metering valve i would definitly remove it just because it will put pressure on the back almost constantly. any pics on the swap? its always good to see how others done it.
Old Nov 8, 2011 | 09:21 PM
clems78's Avatar
clems78
What did you use for the swap
Old Nov 8, 2011 | 09:22 PM
74ford4x4's Avatar
74ford4x4
sorry no pics, (dont now how to post either) I just bought new 84 k20 calipers, rotors and bolt on caliper brackets from ballistic fab. The distribution block is an aftermarket one from Broncograveyard, I bought that before I decided to run disc in the rear. Im thinking I should just remove the distribution block and run direct with adj. valve?
Old Nov 8, 2011 | 09:41 PM
Boba Fett's Avatar
Boba Fett
I have done discs in a bronco and my F150 and I have adjustable prop valves in both.... The bronco was originally 4 drums and needed the adjustable valve in the rear..... The F150 didnt and that was disc front drum rear.... If you want to do this on the cheap put the rear discs on and then bleed the system and try a panic stop.... If the rear brakes lock before the fronts do.... Then you need the valve... A lot will also depend on what calipers, rotors and pads you use.
Old Nov 8, 2011 | 10:16 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
That's the job of the residual valve in the master cylinder.
Josh
Old Nov 8, 2011 | 10:40 PM
clems78's Avatar
clems78
Ok so chev parts on the rear. I like the 2 piston calipers on the front but has anyone done it with ford parts?
Old Nov 8, 2011 | 11:13 PM
Bullitt390's Avatar
Bullitt390
Mustang SVO rear calipers with Jeep CJ7 rotors, custom bracket.
Josh
ManfredVonRichtofen
Mar 21, 2017 06:44 AM
tbruz
Dec 15, 2015 05:40 PM
jeeperman2001
May 8, 2015 06:45 AM
kylecoyote
Sep 17, 2014 09:21 PM
v8xploder
1966 - 1977 Early Broncos
Apr 19, 2009 03:39 PM
