Ya still need a prop valve. See, a light rear end and equalized brake pressure may mean it'll swap ends on ya... ya want to adjust the proportion so the fronts lock up just before the rears.... with a typical load if any.
Ah.. I see. Just delete the former prop valve or use an all-drum distribution block since the rear fluid is already being metered by the "new" prop valve.
A prop valve only controls the bias to the rear brakes.
The MC only has two ports, front and rear. The front can be teed to each front wheel. The rear port of the MC leads to the prop valve (in its simplest form) which has an in and out. Then the rear is split at the rear axle.
What prop valve are you using???
I'm using a Wilwood that has two output ports for the front and one for the rear.
im using one like this near hydroboost.
https://lmr.com/item/M2328C/Mustang-Ford-Racing-Adjustable-Brake-Proportioning-Valve?gclid=COOOpLPC59ICFVQ8gQodAJYF0A
