Power Steering Leak. Help
Old Nov 7, 2011 | 09:51 PM
DutchB100's Avatar
DutchB100
1970 F100 FE360. I installed a new/reman Ford power steering pump and new pressure line. Right where the line connects to the back of the pump, it leaks pretty good. Fluid drips pretty good right out the coupling. Is there an o-ring between the male and female connections? Any Ideas?
Old Nov 7, 2011 | 10:43 PM
elgemcdlf's Avatar
elgemcdlf
Is it leaking from the fitting screwed into the pump or from the fitting on the end of the line?
Old Nov 8, 2011 | 12:19 AM
DutchB100's Avatar
DutchB100
It's leaking right where the fitting connects to the pump.
Old Nov 8, 2011 | 06:25 AM
elgemcdlf's Avatar
elgemcdlf
Take the hose off and then take out the fitting from the pump. It just unscrews & you won't hurt anything. I don't remember if it has an O ring or not but logic tells me it should or some form of sealing as in flare. If the fitting is loose that's your problem. If a flare seal it will be loose or the pump is damaged internally. If O ring or similiar gasket make sure it has the gasket or just replace it.
Old Nov 8, 2011 | 07:43 AM
tmcalavy's Avatar
tmcalavy
the threads on your hose fitting or where it screws into the gearbox are worn...get some yellow teflon tape (solvent safe) and apply it to the fitting threads. also make sure the flare on the end of the hose is good...if its not good, flat and round it will never seal. if there is no flare you may need an o-ring...or could be that someone before you put the wrong hose on the truck...did you keep the old hose? if so, check to see that the new one is the same...parts store folks sometimes give you the wrong parts and some replacement parts are crap.
Old Nov 8, 2011 | 08:53 AM
DutchB100's Avatar
DutchB100
Both the line/fitting and pump are new. It's either leaking out where the fitting is threaded to the back of the pump or where the line come out the fitting. The pump and gearbox are fine. I've checked all over online and there's never mention of a o-ring. I'll try to back out the fitting and tighten it again.
Old Nov 8, 2011 | 10:54 AM
MIKES 68 F100's Avatar
MIKES 68 F100
if it's a repo line there's your problem , like said before get some yellow teflon tape .
i've had 3 different repo hose on my 66 mustang p/s all leaked , only a little but if you're like me a little is to much when it comes to leaks .
Karruda
Sep 23, 2015 08:46 PM
01raptor
Oct 9, 2012 01:03 AM
fx8racer
1997 - 2003 F150
May 10, 2010 07:53 PM
RTM
Jun 26, 2004 07:54 AM
joezee
Dec 28, 2002 10:20 AM
