power steering line leak?
Old Jun 25, 2004 | 11:53 AM
RTM's Avatar
RTM
My neighbor has a power steering from the pump and the high pressure line. I just wanted to know if this a common problem or not. I will replace it for him this weekend.
Old Jun 26, 2004 | 05:19 AM
rozett's Avatar
rozett
Mine started leaking power steering fluid about a week ago. But since the pump is making groaning noises, I suspect that a pump seal is leaking and the pump needs to be replaced. Maybe I should slide under the X and have the wife turn the wheel to make sure it is not just a leaky line.
Old Jun 26, 2004 | 07:54 AM
RTM's Avatar
RTM
If your low on fluid you will get that wine as well. On this truck I can see for sure it is from the HP line. The truck being so new I am surprised the PS line is leaking.
