problem
Old Nov 5, 2011 | 07:44 PM
49 Ford F-1's Avatar
49 Ford F-1
problem
I was walking by my truck about 5 mins ago and heard a vibration coming from under the hood. I opened the hood and it was a pump vibrating. The pump is behind the passenger side battery. Anyone knows what this pump is for, and what the problem is? I unhooked it and it stopped vibrating. Thank yall
Old Nov 5, 2011 | 07:49 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
That is your vacuum pump. It should vibrate. Perhaps it has come loose and is making excess noise against the fender.
Old Nov 5, 2011 | 07:58 PM
49 Ford F-1
So even with the truck off it should vibrate? The truck had been started today. My dad's don't.
Old Nov 5, 2011 | 08:11 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
If the truck is on the pump will still work even if the engine is off.
Old Nov 5, 2011 | 08:17 PM
49 Ford F-1
What caused it to start vibrating? I never heard it before.
A/Ox4's Avatar
A/Ox4
9 ECHO 1
It will runs quite frequently. It provides the vacuum for ESOF and HVAC.
Old Nov 5, 2011 | 08:22 PM
49 Ford F-1
I unplugged it, so should I plug it back up?
A/Ox4's Avatar
A/Ox4
9 ECHO 1
If you want ESOF or HVAC I would say so. Just make sure that its securely fastened if you're worried about excess vibration.
Old Nov 5, 2011 | 08:24 PM
49 Ford F-1
ok thank you.
alabamatoy
Aug 10, 2019 09:56 PM
slayerman54
Jul 16, 2011 11:47 AM
kupaa
Feb 1, 2009 04:06 PM
m.i.nutz
Jan 24, 2009 11:11 AM
weldboy
Jul 27, 2007 01:57 PM
