Fuel leak
Old Nov 5, 2011 | 01:25 PM
04Terminator's Avatar
04Terminator
Fuel leak
What is between the head and the up pipe on the drivers side that could be leaking fuel? Both fuel lines from the housing to the heads are dry and nothing in the valley. The leak is small and just started.
Old Nov 5, 2011 | 01:32 PM
04Terminator
Sorry its a 01 f-350 with a 7.3
Old Nov 5, 2011 | 02:50 PM
DieselOrings's Avatar
DieselOrings
SPONSOR
There is a 1/8"NPT plug located on the driver's side about the same position as where the fuel line connects to the rear of the passenger's side that could leak but would be rare unless someone pulled it and did not use a pipe dope when reinstalling it.
On the rear of both heads, there is a banjo bolt style of plug that plugs the fuel rail from when the head was manufactured. This bolt (plug) is sealed with an o-ring that can leak but it would run down the rear of the engine.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzle
guzzle's Mods & Maintenance website
Old Nov 5, 2011 | 02:54 PM
Bonanza35's Avatar
Bonanza35
GOOD RIGHT UP BOB!
Chet
Old Nov 5, 2011 | 04:23 PM
04Terminator
It's running down the back of the head/block gotta get a mirror and pinpoint it thanks for responding.
Old Nov 5, 2011 | 05:12 PM
04Terminator
Thanks for pointing me in the right direction it was the 1/8 plug on the head barely finger tight must have vibrated loose a bit. pulled it out cleaned it and thread taped it and installed. Glad it caught my nose at the gas station and on my day off too.
Old Nov 5, 2011 | 05:45 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Read this. It will help you fix your leak.
https://www.ford-trucks.com/forums/1...l#post10922146
Old Nov 5, 2011 | 08:38 PM
Bonanza35's Avatar
Bonanza35
Its not a good idea to use tape. Hope there was know extra tape on there to work into the injectors. They use dope for fuel.
Chet
Old Duke 6
Nov 6, 2013 05:01 PM
bill1954
31
Jul 26, 2012 06:54 PM
Oversize
Oct 1, 2009 08:43 PM
rgconway
Dec 20, 2008 03:44 PM
teederj2002
Jan 20, 2007 03:50 PM
