Keyless Keypad stopped working
Old Nov 5, 2011 | 11:49 AM
604excursion's Avatar
604excursion
Hi Guys
My keyless keypad has stopped working on my 04 Excursion, any ideas what could be wrong.
Old Nov 5, 2011 | 12:18 PM
DPorter's Avatar
DPorter
Is it the stick on type? They have a battery in them that needs to be changed.
Old Nov 5, 2011 | 04:09 PM
604excursion
I don't think so it's the one on the outside of the drivers door.
Old Dec 4, 2011 | 11:49 AM
DPorter's Avatar
DPorter
stick on's where/ccould be on the door, mine is, is it about 3/4 inch thick or thin like less than 1/4 inch. The thick one has a battery. the thin one is hard wired I believe.
Old Dec 4, 2011 | 12:20 PM
housedad's Avatar
housedad
I would imagine the "stick on"types are aftermarket or dealer installed accessories on other vehicles. If it is one, definately check the battery. however, according to my Source books, all years of Excursions came Standard with the keyless system.
Does it have power? Does it light up when you press a key? If so, then try the original factory code.
If the factory code does not work, and it does have power, then the keypad is probably the problem and would need replacement.
If no power, then check the fuses that operate it. Also check the wires and grounds for that circuit.
Old May 2, 2013 | 05:21 PM
mmsports's Avatar
mmsports
So I replaced my key pad and mine still does not work.
press buttons it lights up but that's it. it will not lock or unlock. it was at first intermittent now I it just does not work at all.
any other ideas?
If no power, then check the fuses that operate it. Also check the wires and grounds for that circuit.[/QUOTE]
Old Jun 17, 2013 | 02:38 PM
Thor2911's Avatar
Thor2911
Unhappy
Did anyone solve this issue? I have the same issue that just started.
Old Jun 17, 2013 | 03:30 PM
mmsports's Avatar
mmsports
I think I have a bad connection or bad plug in. now that it's warm it is working fine. I bought a new key pad and still did not fix it.
67nukeford
19
Oct 16, 2023 09:05 PM
ilaybrk
Apr 19, 2017 12:10 PM
simplywebb
2004 - 2008 F150
Mar 18, 2014 06:02 PM
Josh Baker
Nov 11, 2013 01:50 PM
vbtackle
Aug 4, 2006 08:22 AM
