Speedo bounce
Old Oct 7, 2018 | 08:57 AM
ScottyC50's Avatar
ScottyC50
Speedo bounce
So here is a new question....after painting the gauge needles yesterday, I was taking the paper towel out from behind the speedometer and other gauges. The needle moved a little, but moved back down after the paper was removed. Now, today, the speedo is bouncing. No problems before today. I am guess first is to check the speedo cable to the back of the cluster. I pulled the cable out a bit (not even an inch 0 there was slack) when taking the cluster out yesterday. My question is - is it probably a cable problem, or did I hit something moving the paper towel and the needle when painting yesterday? I will put the cable back today (put it back an inch). Any ideas?
Old Oct 7, 2018 | 10:54 AM
ScottyC50's Avatar
ScottyC50
Fixed....the speedo had come loose a bit when taking the cluster out.....cleaned up and good as new...
GeneGregory
Sep 15, 2015 05:15 PM
midsouth
Nov 4, 2011 07:57 PM
Conanski
Dec 1, 2010 01:26 PM
grey77
Mar 21, 2005 08:24 AM
GammaDriver
Jul 4, 2002 09:59 AM
