additives
Old Nov 3, 2011 | 01:40 AM
Dmacsuperduty's Avatar
Dmacsuperduty
additives
Alright, I am trying to get peoples opinions on which additive to use. I drive the truck daily and not very hard, trying to add some life to my injectors.. also, what else can i do for added service time on my injectors?
Thanks all
Old Nov 3, 2011 | 01:57 AM
Dieselpop's Avatar
Dieselpop
Thanks all
If you want to add life to your injectors get a fuel pressure gauge because under 45lbs at WOT will kill injectors, run Syn oil 5w40 use only Ford filters keep good batteries in it because weak or bad batteries will kill the FICM then it will kill the injectors. You can run REV-X Oil Additive | Diesel Fuel Additive | High Performance Oil in the oil and use Ford cetane boost in the fuel. Remember the trucks are not grocery getters so once a week drive it like you stole it to keep the egr valve and turbo clean and working because if they set the unison ring may rust up in the turbo then you will have problems. Get some gauges like the Edge Insight CTS the check EOT-ECT max spread 15* more than that cooler problems and the list goes on.
pop
Old Nov 3, 2011 | 02:01 AM
Dieselpop's Avatar
Dieselpop
This may also help
http://www.alliantpower.com/pdf/APTB-0109-watermark.pdf
pop
Old Nov 3, 2011 | 07:03 AM
Rob.D's Avatar
Rob.D
Fill up with B5-B20 biodiesel if it's available. Best form of lubricity you can get.
Old Nov 3, 2011 | 07:44 AM
tex25025's Avatar
tex25025
No additives at all. Zero issues to date. Additives are not something that I subscribe to, but it could also be that I live in 2 states in the South and that might have something to do with it.
Old Nov 3, 2011 | 08:57 AM
bismic's Avatar
bismic
Additives can prevent algae buildup if you leave fuel in the tank for long periods. They can also help demulsify water so it can be more effiiently removed, they can improve cetane values which can help combustion efficiency, and they can help with lubrication. How much they can help is limited, and the effectiveness also depends on the quality of fuel you get.
I use additives as a precaution. I can not say that the use of additives (I have used stanadyne, B5, and DieselKleen) has noticeably helped anything, but then I don't think I have gotten a bad load of fuel yet (in this truck anyway). I have gotten bad fuel in my old 7.3L so it does happen, but I think it is pretty uncommon.
Old Nov 3, 2011 | 11:57 AM
steven06's Avatar
steven06
I have often thought of runing the white bottle of DieselKleen in the summer months, I had a terrible day last winter at about -20 with a little candle wax in the fuel filter, to cold to ever repeat again. Explaining why you are going to be late to work because your fuel is gelled to someone who thinks diesel is an actor is not very fun. So for now every single tank in the winter its some grey bottle.
Old Nov 3, 2011 | 12:27 PM
zhilton's Avatar
zhilton
B5 is the best way to get add lubricity into your fuel...which will help the plungers inside the barrel (what actually forces the fuel into the cylinder). The problem with running anything above B5 is (A) if you still have a warranty on the truck, Ford can denie any claim and (B) biodiesel will gel at a higher temp (some as high as 40F). Just like the oil debates on here, it's an open debate weither the fuel is too dry for our trucks. I've run B20 in years past, other than a slight (0.5 to 1 mpg) lose in fuel mileage the truck showed no ill effects. The key to a long happy life with a 6.0L is doing the PM's on time and with the right fluids & filters. I don't subscribe to the snake oil in the motor oil theory; but to each their own.
Think you've got it backwards, pretty sure you want to use white in the winter, gray in the summer. The white bottle has the anti-gel; the gray is a cetane & lubricity booster.
That's not what diesel is?
Old Nov 3, 2011 | 12:57 PM
steven06's Avatar
steven06
Yep your right I sure do have it backwards, sorry been a while since Ive been home funny how things fade.
Old Nov 3, 2011 | 01:28 PM
XB70's Avatar
XB70
I've always run Power Service (Diesel Kleen) in my truck, double dosing the white bottle anti gel when temperatures drop below the ASTM Pour Point Temperatures for winter diesel: ASTM pour point temperatures
Note that the chart shows the pour point for diesel fuel, not the cold filter plug point. Pouring diesel out of a beaker is not the same as getting it through a three or ten micron filter.
Power Service has always kept my truck running, even during extended periods of -25F and I'm able to get the chemical engineer who designs the products on the phone for technical questions. Both give me a lot of confidence in Power Service products.
I know Power Service anti gel works because I've passed a parking lot full of diesels towed to the ford dealer with gelled filters more than once,
Old Nov 3, 2011 | 01:29 PM
IABill's Avatar
IABill
Wink
This is a bit old but it confirms what Z says
http://www.natbiogroup.com/docs/educ...%20results.pdf
Old Nov 3, 2011 | 01:37 PM
Stu206's Avatar
Stu206
According to Ford, using BIO not over a B5 mix in tank and use Cetane Booster in tank helps everything work better. I have been getting B20/B99 cheaper then Ultra Low all during the summer, now has been cut back to B75 for winter Blend. I usually put 5gal of B99 in then fill truck with Ultra Low for a mix in the tank, if I am gonna be towing my 5ver. Just a reg fill-up put B20 in on a fill, I have a transferflow 57 gal tank on my truck. So can travel a ways down the road, average around 10.5 to as hi as 11.7 while towing my 5ver at 11K down the road.
Old Nov 3, 2011 | 05:55 PM
Mich6.0's Avatar
Mich6.0
Hope it doesn't get below 32 deg because problems will arise quickly
Old Nov 3, 2011 | 07:10 PM
Rob.D's Avatar
Rob.D
Power Service white bottle for the cold Michigan winters. No worries.
holdtyte
Jan 3, 2014 07:48 PM
Jknapp79
Apr 25, 2012 01:51 AM
joe blow
May 24, 2011 11:25 PM
powerstroker88
Jun 28, 2007 11:39 AM
adambomb
May 16, 2007 07:56 PM
