Engine swap?
Old Oct 29, 2011 | 10:06 PM
LuckyHorse426's Avatar
LuckyHorse426
Question Engine swap?
Hey everyone!
I was wondering if it's possible to swap out my 1979 302 V8 5.0L engine for a larger, newer model? It does have stupid California emissions control systems on it, and I'm assuming any newer models have it as well.
Truck Specs
1979
F100 Custom
302 5.0L V8
Automatic Transmission
I'm kind of new to this whole thing so any advice would be greatly appreciated!
Old Oct 30, 2011 | 12:28 AM
Fordfreek!'s Avatar
Fordfreek!
To answer your question, Yes, you can. But....you will definitely have to be more specific than "a larger, newer model." It all depends on what you want and what you want to spend. You could go the fuel injected 460 route if you're wanting more power on a bigger motor. It all depends on what you want out of the swap as in power, fuel economy, etc.
Old Oct 30, 2011 | 10:38 AM
HIO Silver's Avatar
HIO Silver
Originally Posted by Redneck Romeo
Hey everyone!
Think twice about "swapping" to a newer engine.... I sure as hell wouldn't do it.
Your rig is NOT exempt from emissions and the BAR/CARB/DMV will require that you meet the emissions standards and have the equipment of the newer engine. Meaning, you can "update" but you have to install EVERYTHING emissions-related of the newer engine and pass the typically more stringent sniffer test... along with visiting a CARB-certified Referee Station, get a certification test, visual test, and pay fees up the ying-yang.
Here's where it gets fuzzy. It is possible to install a newer engine and dress it up like a 79 and run the 79 smog stuff. Most techs won't get picky but there is a chance one will. Never say "engine swap" when talking to the smog tech.... it tends to mean a non-stock configuration for your particular truck (like a 460 in place of the 302). Instead, use the term "engine replacement" which means it's still the same configuration but not the original block. It sounds like semantics but VERY important to keep in mind.
If you wanna do a build up, buy yourself a 1975 or older vehcile because they are exempt from all emissions tests... notice the years of my toys in my signature. Get it??
Old Oct 30, 2011 | 11:12 AM
LuckyHorse426
Ah ok, thanks for all the great information guys, I'll make sure to keep that in mind! My other favorite classic fords are the '55 F100 and the '48 F6. Maybe i can find another project among those!
Thanks again!
Zorks
1997 - 2003 F150
Mar 18, 2009 06:29 PM
CharGriller
Engine Swaps
Jan 16, 2009 11:21 PM
jse1958
1997 - 2003 F150
Oct 30, 2006 09:38 AM
BChinn
Engine Swaps
May 18, 2006 11:01 AM
bluesuedetruck
Dec 13, 2005 06:23 AM
