Help with Engine Swap
Old May 16, 2006 | 08:53 PM
BChinn's Avatar
BChinn
Hey everyone newbie here. I just have a small question. I have a 73 F100 with a 400m in it. The motor has seen better days, I have found a 84' F150 truck with a 302 in it and i was wondering what all i need to do to make this 302 work in my truck I'm wanting the motor and trans that's in the 84'. Please let me know if there is going to be any problems with this swap. Thanks
Old May 16, 2006 | 09:29 PM
Mil1ion's Avatar
Mil1ion
May I be the first to welcome you to the site
The 400 (No M) uses completely different ....everything compared to the 302.
You are best off with having a donor truck of the same years.
What transmission is hooked up to the 302 ?
Old May 16, 2006 | 09:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old May 17, 2006 | 03:17 PM
BChinn's Avatar
BChinn
I'm not sure what kind of transmission is in the 84' F150 I'm just wondering if i'll need to make new motor mounts or if i can use the same ones that was in the 84' F150, Also if i'll have to replace my drive shaft with one with a carrier bearing. That kind of info if u can. Thanks again.
Old May 18, 2006 | 11:01 AM
loudfords's Avatar
loudfords
You can use the 84 motor mounts and the 73 frame towers just fine - hopefully the 73 will have the correct frame towers since that 400 is not an original engine in a 73.
