Amp Remote Power Source
Old Oct 29, 2011 | 03:44 PM
Panzerbrumbar's Avatar
Panzerbrumbar
Well I just got done installing an amp and sub in my 11 Screw and I found most everything in here for the install. The only thing I did not find was the amp remote power wire. There is none at the head unit. Well I did some digging and finally found one. In the passenger side front door sill in the big bundle of wires there is a solid blue 14 gauge wire that works perfectly. It is the same power feed for the windows, stereo and all the functions that stay on until you open the door if that makes sense. Hope this helps with anyone looking to install and amp or anything you want keyed power source and it is easy to get at and I hate those add a fuse power sources they look tacky and get in the way if you ever have to get into other fuses.
classic_custom 79
Mar 24, 2015 12:56 AM
79_ford_400_guy
Feb 14, 2013 06:49 PM
RCOAPSTICK
May 14, 2004 05:18 AM
chriskli7
Aug 2, 2003 10:03 PM
oft
Jul 25, 2002 07:26 AM
