Sponsored by: Innova
Controlling On/Off for Amp
Old Mar 19, 2004 | 05:10 PM
RCOAPSTICK's Avatar
RCOAPSTICK
Question Controlling On/Off for Amp
Amp: KENWOOD KAC-8401
There is a "power control terminal" on my amp. instuctions say:
"4.) Connect the speaker wires.
5.) Connect the power wire, power control wire and ground
wire following this order."
The "Power control terminal" is said to "Control the unit
ON/OFF."
I was wondering what to connect the "power control wire" to after it is connect to the amp. Is there some way i can install a switch so that i can turn the unit on/ off manuallly?
Old Mar 19, 2004 | 05:14 PM
akford351's Avatar
akford351
You should hook it up to key-on power source (turns on when the truck is on)... usually on a HU wiring there is a "Remote Wire" you hook that up to. Be much better than having to flick a switch on and off all the time; lessen the chance of you forgetting it on and returning to a dead truck.
Old Mar 19, 2004 | 07:43 PM
94Bronco58's Avatar
94Bronco58
That is exactly what your looking for, I have a Kenwood amp, and hooked it up through the Headunit!
Old May 13, 2004 | 11:48 PM
sk8ingsmurf's Avatar
sk8ingsmurf
I have an amp in my 99 eb expedition and what I did was ran the wire fromt he back of my head unit (remote turn on), (head unit is an eclipse 8443), to the amp (fosgate 1001bd), then I cut it in the middle and installed an on off switch. So the amp only turns on when the car is on but when the car is on I can still turn it off if I want.
A switch can be found at any radioshack or partsexpress, any electronics store pretty much
Old May 14, 2004 | 05:18 AM
prcrboy's Avatar
prcrboy
Dont' do the switch unless you plan on having a dead battery someday. Hook up to any power source that is controlled by inginition. There are two options on radio, even if a factory setup. Tap into ingnition wire on radio, or remote turn on. Ford did install one on the factory if the radio is not just plain am/fm. It is in the 20 pin connector. color is light greeen with black stripe.
joeycyph56
Jan 11, 2015 10:25 PM
DDPJ
Oct 4, 2014 06:51 AM
Gundown64
2004 - 2008 F150
Dec 23, 2011 06:32 PM
Woodsman_30350
Sep 13, 2008 01:02 PM
cmac1442
Jan 1, 2004 11:43 PM
