99 F250 SD Headliner Removal
I just lowered it enough to do the work vs removing the entire thing. Seemed much easier. The driver's side A pillar just pops off, remove the passenger side grab handle and that A pillar cover will come off as well. Pull down the rubber trim around the door opening and the headliner will fall down enough to do the work.
If you have the overhead console, you will have to remove it also.
Here is a link to when I installed lights on my wife's truck.
https://www.ford-trucks.com/forums/1...hts-today.html
Built_Ford_Tough_757
1999 to 2016 Super Duty
07-25-2010 01:23 PM
