Sponsored by: Real Truck
V-10 custom tuning
Old Oct 20, 2011 | 09:42 PM
es1982's Avatar
es1982
V-10 custom tuning
Hello, I am putting together a v-10 for my 1999 f-250. It has PI heads that have been ported along with the intake, a set of comp cams and is bored .030 over. I have a diablo sport tuner in the truck and am planning on a larger throttle body and Banks long tube header the compression will be about 10:1. I am wondering about the diablo turner and what i will need to change due to the mods I have and will I need a bigger set of injectors?
Old Oct 21, 2011 | 11:14 AM
Furian's Avatar
Furian
You Keep What You Kill
With those upgrades, you will definitely need a "custom" tune and probably some dyno time. Where did you find the Comp Cams for the V10? I believe that they have been discontinued by Comp Cams. As for new injectors, I don't think that you will need them. If you were installing a supercharger, then definitely yes.
Hopefully other FTE members will chime in with their recommendations.
Welcome to FTE!
Old Oct 21, 2011 | 02:06 PM
doofuss's Avatar
doofuss
You need the Y pipe for the exhaust for sure
Old Oct 26, 2011 | 06:53 AM
es1982's Avatar
es1982
the truck won't have a Y-pipe i'm gonna build a 3inch headerback exhaust. I sent my cams to Comp and had them re-ground.
Old Oct 26, 2011 | 07:12 AM
pappy19's Avatar
pappy19
I ran a diablo for a long time and had no complaints but recently I purchased a custom tune from Mike at 5-Star and the difference is amazing. With your setup, you really need to talk to Mike.
5 Star Tuning | Custom Dynomemeter Chassis Tuning Products and Services
Pap
Old Oct 26, 2011 | 11:15 AM
spinella's Avatar
spinella
+1 with mike at 5 star. check out the v10 section, lots of good info there.
Old Oct 26, 2011 | 12:03 PM
dkf's Avatar
dkf
The Diablosport tuner will be fine you just need to get a some custom tunes for it. Th ebest way is to find a shop that supports the Diablosport hardware/software and have them dyno your truck and sell you the custom tunes. Since you put some coin into the engine thus far you might as well spend the little extra a get it dialed in on the dyno. The Diablosport canned tunes that come with the tuner are junk but there software and hardware setup is good. A lot of custom tuning shops use Diablosport. I just don't see the need to spend money and go buy another tuner when your current tuner is up to the task. Better off spending that money at the dyno IMO.
I don't think you changed your fuel requirements enough to need a set of larger injectors but I could be wrong. The shop that does the tuning can let you know. If you go with dyno tuning you WILL find out for sure if your current injectors are up to the task.
LaughingSavage
Modular V10 (6.8l)
98
Mar 27, 2023 05:26 PM
Jessi Evans
Jan 8, 2017 06:02 PM
BirdDogV10
Sep 27, 2011 01:51 PM
PMDRACER
Modular V10 (6.8l)
22
Feb 4, 2007 05:24 PM
mstennes
Modular V10 (6.8l)
Mar 6, 2005 05:20 PM
