Sponsored by: Real Truck
ADDING FUEL ECONOMY COMPUTER
Old Oct 24, 2011 | 10:09 PM
rickster90's Avatar
rickster90
Smile ADDING FUEL ECONOMY COMPUTER
I just purchased a 2005 Ford F350 Diesel Crew Cab XLT LWB 4WD. It is loaded with everything as the Lariat except the white gauges and the trip computer/economy features. I know the previous years had the overhead console, but I believe in this year it was manufactured into the instrument cluster. I was interested in adding that to my instruments. Can anyone tell me is that feature actually in the instrument cluster and if so can a module be changed to add that feature? I know in a lot of the newer cars those features are built into the stereo/security systems. I looked on the Ford parts.com website and couldn't find a specific module or part. Any help appreciated.
Old Oct 24, 2011 | 11:32 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Put a Lariat cluster into the truck and the 3 associated buttons
Check to see ifthe wiring is there. If not, impossible swap
Cluster will have to be programmed at Dealer. But is a very easy swap
Have you looked at getting a scangauge? Does the mpg stuff, plus its a great gauge source.
Old Oct 25, 2011 | 12:11 AM
3cv's Avatar
3cv
scangaugeII is awfully nice, punched in the mess of a code and now get trans temp along with fluid temp, avg and instant mpg as my normal. Was begging for the last .1 mpg avg on the way home tonight coasting into the driveway, had to settle for 12.9.
It has also been a great tool in the Honda minivan on trips, just takes a couple minutes to change it over if that.
Not built-in styling though.
Old Oct 25, 2011 | 12:03 PM
rickster90's Avatar
rickster90
I have looked at getting a programmer for economy and towing. Thanks very much fot the info on the plug in the dash. I will check with Ford I saw an interior decoder for F150, F250. Do you guys know if that works for F350's?
Old Oct 25, 2011 | 01:25 PM
VONxRUBENxLA's Avatar
VONxRUBENxLA
im gonna be getting a scan guage II 1 day instead of fixing my lie-o-meter. i dont need to know what the temp is outside or the direction im headed thats what the iphone is for lol
Old Oct 25, 2011 | 02:00 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
You have the 6.0L... you need the gagues anyway. A SC works, but I think the screen and backlighting sticks out really bad in the truck. If you want a clean look that doesn't stick out as much to match your Lariat interior, get an Edge Insight CTS or Edge Insight CS and put it on a dash pod. The Insight CTS or CS will show instant and average MPG, in addition the everything else you should already be watching. Investing in the ability to watch your coolant and oil temps, plus FICM voltage, battery voltage, and a few other things, can drastically reduce your chances for engine problems and expensive repairs. The CTS does all this out of the box, and with the right accessories (that the Scanguage can't be upgraded for), you can watch other important things like fuel pressure and exhaust temps.
You should really read these threads:
https://www.ford-trucks.com/forums/7...-problems.html
https://www.ford-trucks.com/forums/9...used-6-0l.html
https://www.ford-trucks.com/forums/7...ew-owners.html
https://www.ford-trucks.com/forums/3...ch-folder.html
Edge Insight CTS:
Old Oct 25, 2011 | 02:06 PM
VONxRUBENxLA
Originally Posted by texastech_diesel
You have the 6.0L... you need the gagues anyway. A SC works, but I think the screen and backlighting sticks out really bad in the truck. If you want a clean look that doesn't stick out as much to match your Lariat interior, get an Edge Insight CTS and put it on a dash pod. It'll show instant and average MPG, in addition the everything else you should already be watching. Investing in the ability to watch your coolant and oil temps, plus FICM voltage, battery voltage, and a few other things, can drastically reduce your chances for engine problems and expensive repairs. The CTS does all this out of the box, and with the right accessories (that the Scanguage can't be upgraded for), you can watch other important things like fuel pressure and exhaust temps.
Anything similar to this for a gasser
Old Oct 25, 2011 | 02:21 PM
F250CCowner's Avatar
F250CCowner
Interesting but does it cost $159? I have a little 5.4L and that might be overkill. Doesn't mean I wouldn't like to have it though.
Old Oct 25, 2011 | 02:30 PM
texastech_diesel
Token Redneck
Edge markets the Insight CTS on their website as being for diesels, but sells what looks to be the same box of parts as the Evolution CTS programmer for gassers, so I don't know for ceratin if the Insight would work on a gas engine, but I imagine Edge could tell you if you called.
As for the cost... I'm willing to pay more to get a screen that doesn't make the resolution on a TI-83 look like HDTV. I appreciate the expandable functionality of the SC as a diagnostic tool, but I don't want to have to look at it all the time.
Old Oct 25, 2011 | 03:05 PM
F250CCowner
I'm a function over form kinda guy. Either way both work. The Insight CTS is a very cool and necessary component on a diesel rig I would assume. I like the install on your truck it looks very clean.
Old Oct 26, 2011 | 12:15 AM
rickster90's Avatar
rickster90
Thanks I'll check that one out. I like the look of how the Edge blends with the Ford dash but it is a pretty basic programmer.
jmo1112
Mar 11, 2016 09:17 AM
thegreatgate
2004 - 2008 F150
Jul 18, 2015 11:10 PM
pukemon
2004 - 2008 F150
33
Sep 12, 2009 05:35 AM
SG1NUT
Sep 12, 2008 11:03 AM
86halfton
2004 - 2008 F150
May 13, 2008 07:10 PM
