Clunk when shifting
Old Oct 24, 2011 | 10:01 PM
tylerhughes's Avatar
tylerhughes
Clunk when shifting
Earlier today I hopped into the Ex to move it across the driveway and my buddy pointed out a "clunk" when I shifted into reverse, and then again to drive. He thought it must be the U-joint but I crawled under and the drive shaft was tight.....so you think it's something I should be worried about? I would much rather pay now to replace something preventative (even if it is major) then be stranded somewhere down the road! I want to keep this thing on the road as long as possible
Old Oct 24, 2011 | 10:40 PM
wpnaes's Avatar
wpnaes
IMO, a clunk when going from Drive to Reverse is just wear and tear on the driveline. Crawl underneath and turn the driveshaft by hand with the trany in Park, there's some give even with tight u-joints. Just drive an enjoy, you've got better things to worry about.
Old Oct 24, 2011 | 10:44 PM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Here take a look here!
https://www.ford-trucks.com/forums/1...l#post10716212
Old Oct 24, 2011 | 10:47 PM
tylerhughes
Originally Posted by wpnaes
...you've got better things to worry about.
you can say that again man!
Old Oct 24, 2011 | 10:51 PM
wpnaes's Avatar
wpnaes
Good point Steve!
Here's some pics Tyler.
https://www.ford-trucks.com/forums/1...nion-seal.html
Old Oct 25, 2011 | 07:17 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You can't check for bad u-joints with the driveshaft in the truck, unless they are so bad they are about to drop out of the shaft. The only way to know if the u-joints are bad is to remove the driveshaft.
Old Oct 25, 2011 | 07:40 AM
7.3mongo's Avatar
7.3mongo
I was about to say the same thing.
Old Oct 25, 2011 | 09:29 AM
tylerhughes
Well at least we know we're not to that point yet! Looks like a project for next week
screwy
Feb 23, 2020 08:25 AM
94wyatt95
Jul 25, 2014 01:15 AM
demonhead
Modular V10 (6.8l)
19
Oct 4, 2013 09:48 PM
993/4ton
Feb 24, 2007 11:27 PM
50jd60
Dec 29, 2004 06:55 AM
