Sponsored by: Real Truck
Clunking when moving from stop
Old Aug 17, 2011 | 10:55 AM
EMS-guy's Avatar
EMS-guy
My 99 screw with a v10 runs great, but clunks as I pull away from stop signs or lights. He harder I hit the gas, the harder thit "hit". Opposite if I eas into it. I've climbed underneat it and watched the driveline as my wife worked the truck back and forth. Everything looks tight, and the shafts don't move when the truck is in park or neutral. I'm kinda thinking engine or tranny mounts?? It doesn't clunk or anything if it's in gear and I stab the gas after coasting a bit. It's been my experience with ford ambulances that the u joints are shot when it clunks then. Any ideas?
Old Aug 17, 2011 | 11:07 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have a look at this. I think this is your problem. Slip joint regreasing
Old Aug 17, 2011 | 11:13 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Ditto on the Slip joint re-greasing thread!
Major reminder! Remember to block your wheels before removing the shaft!
Old Aug 17, 2011 | 11:16 AM
EMS-guy's Avatar
EMS-guy
That seems like a simple place to start. I wanted to ad that the clunk was a very deap sounding, almost a thud, that jolts the entire rig.
Old Aug 17, 2011 | 11:36 AM
miller_feed
Give this a try. It does feel that way when the splines are dry.
Old Aug 17, 2011 | 11:38 AM
EMS-guy's Avatar
EMS-guy
Cool. I'm excited that the first relply wasn't something dumb that I have to pull the frame off.
Old Aug 17, 2011 | 12:03 PM
miller_feed
Naaa, you just need to pull the engine and trans for this.
Old Aug 17, 2011 | 12:07 PM
EMS-guy's Avatar
EMS-guy
F that. I'll trade it in on a diesel before I try all that in the driveway. Haha. Hopefully the driveshaft comes off easily enough. It's got 218k on it, but runs like new.
Old Aug 17, 2011 | 04:00 PM
robd928's Avatar
robd928
Mine did the same...I pulled the driveshaft and found the splines dry...re-greased and all is well.
Rob
Old Aug 17, 2011 | 04:02 PM
miller_feed
Old Aug 17, 2011 | 07:59 PM
mtdigger's Avatar
mtdigger
Ditto...on the wheel chock reminder..!!!! Don't ask how I know...but a driveshaft across the bridge of the nose, feels like a Louisville slugger. ALWAYS block the wheels
Old Aug 17, 2011 | 08:04 PM
EMS-guy's Avatar
EMS-guy
Haha. Well noted.
Old Aug 17, 2011 | 08:26 PM
davidjurss's Avatar
davidjurss
I know that feeling all too well. Wife came running out of the house because she heard a thud, then saw all my tools come flying out from under the truck with words that would make a Sailor blush.
Old Aug 17, 2011 | 08:41 PM
kd0axs's Avatar
kd0axs
Might want to read this.
https://www.ford-trucks.com/forums/s....php?t=1091580
Old Aug 19, 2011 | 07:30 PM
PartsPaul62's Avatar
PartsPaul62
Banned
Drive away clunk
This has been a running TSB thru Ford Motor Co for almost 20 years. Use a silicone grease and it should take care of the noise.
And look elsewhere on this site for the TSB. Ford describes the condition as a "slip-stick" condition.
