Glow plug write up!
Old Oct 25, 2011 | 03:13 PM
SixGunCaliforniaKid's Avatar
SixGunCaliforniaKid
Originally Posted by jayc3169
This only happens when she is cold. After chow (lunch, sorry) Cleared the codes, 0683 and U0360 were still showing up. Turned her off, unplugged the the GPCM and cranked her up. pulled the code 0670 (no other codes). Plugged them back up, cranked and no codes.
Oh my fellow Jarheads.....
heres the thread for your crazy code its got be a BD thing
https://www.ford-trucks.com/forums/1...s-or-gpcm.html
Old Oct 25, 2011 | 07:24 PM
kidoo's Avatar
kidoo
I also thought that the glow plug where pretty good on the 6.0, not many complaint about them. Is it hard to get at? Where are they?
I remember my old 7.3, my head was under the hood every winter for a burnt glow plug.
Old Oct 25, 2011 | 08:54 PM
BLADE35's Avatar
BLADE35
here you go
not to bad to get at helps if you remove the passenger side wheel well
Old Oct 25, 2011 | 10:50 PM
jflo631's Avatar
jflo631
I had 2 glow plug codes and they were not the problem. Replaced them both and truck still startd rough, idled rough and smoked.. Ended up being the FICM, sent it off and had it back in a few days. Starts like a dream!! Check the FICM voltage fo-sho!!
Old Oct 26, 2011 | 03:50 PM
joetama's Avatar
joetama
BLADE35 THNKS
Sorry BLADE35 to be complicate at time to explaine my situation.
the thing is I got a truck F50 6.0L Disel engine as you see the last time; what happing is he is turning (starting) but never ran or crack?
in another words did not work... so I'm planing to replace the haed gaskeck's in orden to see if I got lack of power in the chambers?
I got not code's cause the truck came from auction, so don't know the history behing?.
Do you belive is possible the head gaskeck is blow out? and could be the reason why the engine won run?
Thank you in advance for all your help.
If you have any qst.. I"ll be happy to answer soon.
cheere,
Joe
Old Oct 26, 2011 | 04:00 PM
BLADE35's Avatar
BLADE35
cheere,
Joe
I think that there would be alot of things I would check before Pulling the heads off
Do you have any gauges?????
have you got the codes read??????
Old Oct 26, 2011 | 05:16 PM
joetama's Avatar
joetama
F350
Not now, but do you want me to do the engine compression test?
I'll be looking the gauges if you want?
have you got the codes read?????? not, because my brother in love tell me it wasn't able(don't have any at the time to read) because the lack of time the truck was seating in the yard or where in the auction place.
LSO1123
Jan 28, 2018 11:16 AM
cornstar6207
Nov 27, 2017 11:10 PM
Mattb60
Aug 1, 2013 09:21 PM
Ardvarg
Dec 1, 2007 02:50 PM
Greenlawnracing
Mar 11, 2007 06:02 PM
