The search function is your friends. Search glowplug harness for more detailed information.......and I urge you to purchase a glowplug harness for the particular side you're replacing before you attempt it as the plugs are VERY easy to break.
A couple of codes that I can't find and no one has ever heard of or seen. I get them with my Bully Dog Triple Dog, tried a Autozone scanner and no codes show up. Morning start ups are rough, really rough. Grey smoke when she first starts (only a puff, not consistant) Sounds like she's missing, and no power. Once warm, works normal. First step for me is Glow plugs.
Bullydog's are notorious for false codes and glowplugs will definitely throw codes if they are bad. Like Benny said, post up the codes. I'll check them in my AE database also.
Please tell me if my tuck (F350 Diesel 6.0/2004) Don't start but turn w/ goods bat's etc..
Got leak water at the exaust pipe (at the time to tow to the garage..) was wrong?
or if could be the Engine Cylinder Head Gasket,
may be plugs? or what?
Thnaks in advance!!
JOE
I really can understand what your trying to say
If you have coolant leaking out the tail pipe you have a BaD EGR Cooler
The codes are P0683 (Glow Plug Control Module to PCM Communication Circuit) and
U0360 which doesn't exist. I checked the GPM and the voltage is correct when I tested it as instructed in the Tech folder.
This only happens when she is cold. After chow (lunch, sorry) Cleared the codes, 0683 and U0360 were still showing up. Turned her off, unplugged the the GPCM and cranked her up. pulled the code 0670 (no other codes). Plugged them back up, cranked and no codes.
