Performance/MPG Chip
Old Oct 23, 2011 | 12:43 PM
T-rexjohnson's Avatar
T-rexjohnson
So I am new to this site and also very inexperienced when it comes to performance chips. I am looking for a performance/MPG enhancer chip or program for my 2007 Ford Explorer Sport Trac XLT and I would appreciate any and all help.
Thank You,
Travis
Old Oct 23, 2011 | 09:39 PM
shorod's Avatar
shorod
Contrary to the way they may be advertised, you're not going to find a single program that will increase HP/performance AND at the same time improve fuel economy. That being said, the SCT tuners are likely compatible with your 2007 and can have multiple programs loaded allowing you to relatively quickly switch from a performance tune to a economy tune.
I've gone with Torrie at Unleashed Tuning for my performance tunes and SCT tuner.
-Rod
Old Oct 23, 2011 | 10:36 PM
T-rexjohnson
Thank you for the tips and options. I have looked at the products and regarding the SCT tuners, would it be best to get one with preloaded programs, because i would want one that could get the best fuel economy out of my truck and also ones just for performance purposes. Would it be wise to change the programs on the vehicle for certain things, or would i want to set one and leave it?
Old Oct 23, 2011 | 11:16 PM
KhanTyranitar's Avatar
KhanTyranitar
-Rod
That is false. You are not going to find an off the shelf tune that will give you increased performance and fuel economy, but a custom made tune built using a wideband can lean out the mixture on light throttle to maximize economy, and richen the mixture while running aggressive timing under heavy throttle. You can also change the point as which the computer sees WOT, which if increased, can allow you to apply more throttle without going into WOT enrichment mode.
I have seen several tunes that increased performance and fuel economy at the same time.
Old Oct 24, 2011 | 12:49 AM
T-rexjohnson
where would i find a tune like this/or have one made? and ide have to buy the whole programing tune something like SCT rite?
Old Oct 24, 2011 | 06:49 AM
shorod's Avatar
shorod
Okay, so he's asking for options, offer some up! Unleashed Tuning does offer a package where you can get a custom tune based on dyno results, but obviously you'd need to drive to their shop. Torrie is great at responding to e-mails and seems to be quite patient. I would not hesitate to contact him and ask him what your options are for your particular truck and budget.
As for the SCT tuners, they are serialized for you particular vehicle and they will have pre-loaded tunes for you vehicle based on what types of tunes you want. If you do not have the calibration information for your truck you may need to have the SCT shipped to you first to access the calibration information, provide that code back to the supplier, then they will e-mail you the appropriate tune files for you to upload to the tuner which you can then upload to the vehicle. The parameters that you can adjust are few, such as calibrating wheel size, adjusting pinion size, altering the speed limiter, and minor changes to spark timing, shift pressure, and shift points under WOT.
-Rod
ggood2
Computer Chips & Tuners
May 25, 2013 07:15 PM
davelim
2009 - 2014 F150
Sep 12, 2011 11:15 AM
pdarbs
Feb 17, 2011 12:15 PM
sparke454
Jan 13, 2004 09:50 PM
michaelgoering
1997 - 2003 F150
Jan 4, 2004 07:03 PM
