Oil pressure
This stuff :
Lucas Oil 10001-1 - Lucas Heavy Duty Oil Stabilizer - Overview - SummitRacing.com
My 351 now has it hot at idle w/5w30. Knock and pressure drop.... I can just barely hear this knock but its there with the gauge fluctuation, if you listen for it. 15W40 full to the brim it does not knock or drop pressure. 10W30 with the lucas its fine also. 10w30 alone will do it hot.
Next oil change try the lucas with your normal oil. Add the full bottle it will most likely stop doing it. The bottle is more then a quart. So note it when filling. She still has a long life left, no fears ...
If your using 5w30 time to step it up also. I had a GMC 350 that had a bearing knock as well as what your saying and I drove it for another 50K miles before we traded it. When I say knock im not talking a faint one. Full bore someone is at the door and wants in ... You could hear it over the exhaust 30 feet away. At idle when warm the Pressure would serge 1-5 PSI with the knock. Could not kill the bugger and tried hard.
I have this same problem, except my oil pressure gauge never goes up...NEVER...I thought maybe it was just the gauge that needs to be replaced. because I noticed my engine temp barely gets past cold as well. so I figured maybe there was just something wrong with the gauge. Any ideas?
82ford302
26
04-16-2010 05:15 PM
ford390gashog
28
08-22-2007 07:07 PM
GSchretter
01-21-2000 02:14 PM
